Old 10th Jul 2024, 12:28 am   #1
Buzby123
Buzby123's Avatar
Default NOP generators, different to what I expected.
Browsing round the web, I found these NOP generators ...
http://retro.hansotten.nl/other-retr...u-nop-testers/
These devices are stand-alone devices to test CPU chips by forcing them to execute NOPs, and then viewing LEDs on the address bus as a quick check that the CPU is working.
These are totally different to what I have always known a NOP generator to be.
My understanding, and the ones I built back in the day, was a device that replaced the target CPU in a system, and swept through its address space by executing NOPS. By forcing the RD/WR strobes on every NOP you could do a rough check that all the address decoding was working properly.
So, if somebody said 'I've got a NOP generator', what would you think they had ?
Buzby
https://www.tenacious.org.uk/
Buzby123 is online now   Reply With Quote
Old 10th Jul 2024, 12:59 am   #2
Phil__G
Default Re: NOP generators, different to what I expected.
Hi Buzby
I think its the same thing but one way forces the existing processor in situ to do NOPs, and the other is a plug-in unit probably with the very same processor on a daughterboard, again forced to run NOPs.
I've also seen devices which were just a binary counter feeding the address lines, that could be free-run or single stepped - but thats not a NOP generator, more an 'address sequencer'
Either way I've never used one or felt the need for one
Phil__G is offline   Reply With Quote
Old 10th Jul 2024, 10:10 am   #3
SiriusHardware
They are a pretty much essential first line of attack for working on things like PETs - some of the PET cases we have worked through here would have been much more difficult without having a NOP generator handy to exercise all of the address lines and therefore also the chip select lines, to check that they are all working.
SiriusHardware is online now   Reply With Quote
Old 10th Jul 2024, 11:27 am   #4
ScottishColin
The NOP generator I cobbled together, and then replaced with the one below was designed to be used in the PET itself, and does not have the ability to actually test the 6502 itself which is what the first post seems to do.
https://www.laser.com/product_info.p...oducts_id/1981
Colin.
ScottishColin is offline   Reply With Quote
Copyright ©2002 - 2024, Paul Stenning.
