Old 18th Jun 2018, 11:36 am   #1
TowerRadio
Default Farnell E30/2 PSU transformer burn-up
Can anyone see a problem with replacing a burnt-up original transformer in my E30/2 with 2 toroidals of suitable output which will fit in the void left? The toroids would be flat, one on top of the other, secured to the back panel by a large nut and bolt, flat washer, rubber washer and whatever else it takes to secure them. Les.
TowerRadio is offline
Old 18th Jun 2018, 11:47 am   #2
Sinewave
Sinewave's Avatar
Default Re: Farnell E30/2 PSU transformer burn-up
The only immediate issue is isolation.
Avometer, vintage Fluke and Marconi collector. Also interested in vintage Yaesu and KW.
Sinewave is offline
Old 18th Jun 2018, 1:18 pm   #3
MrBungle
MrBungle's Avatar
Cost might be an issue. If you don’t alresdy have them, two toroids might cost more than a new E30/2 at current prices!
MrBungle is offline
Old 18th Jun 2018, 1:59 pm   #4
TowerRadio
I have two suitable already, bought at what I thought to be a bargain price. So long as I insulate each from the other and both from the case (at the same time allowing for some degree of air circulation) are there any other things that can cause me trouble? The transformer that came with the PSU was burnt up when I got it but I think there was a short to one of the 2N3055 connections at the back. A degree of caution and in-line fuses will be used when I first power on.
Les
Old 18th Jun 2018, 2:25 pm   #5
MrBungle
MrBungle's Avatar
Should be fine then. One thing to note is the E30 benefits from addition of a diode across the terminals and the pass transistor otherwise the load tends to blow the driver transistor if there’s a power failure or overload.
I rather like those little power supplies myself.
MrBungle is offline
Old 18th Jun 2018, 7:20 pm   #6
duncanlowe
I'm sure you know, but just in case, make sure that one end of the bolt is isolated from the case (and will remain so if something gets put on top of the case etc) otherwise you have a nice low resistance single turn secondary.
duncanlowe is offline
Old 18th Jun 2018, 7:29 pm   #7
G4_Pete
Depending on MCB rating and Type and where you catch the turn on cycle you can get enough surge to trip some MCB's with toriods. The ratings for this PSU's toriods might not put you in this region but if you do get a turn on trip then slow turn on might be required.
Pete
G4_Pete is offline
Old 18th Jun 2018, 10:23 pm   #8
TowerRadio
Thanks for everyones advice. When I get round to doing the repairs I will post again. Les.
