Old 1st Jun 2018, 6:29 pm   #1
NormanW
Default PYE W15AM RG connectors
I have an ex MOD 1970's PYE W15AM RG set that I am going to fit back on an ex police bike. I need to get the right connector cover for the control unit (it had a little chain) and also the correct connectors for the antenna and power on the base unit.
Could anyone help and tell me what the part numbers or the type of connectors are that I need to try and obtain please? Photos attached as I can't find a way to put them in line.
Thanks for reading
NW
Name:	pye 05 base connectors.jpg
ID:	163964   Click image for larger version
Name:	pye control connector.jpg
NormanW is offline
Old 1st Jun 2018, 6:51 pm   #2
G6Tanuki
G6Tanuki's Avatar
Default Re: PYE W15AM RG connectors
That's a pretty standard "Plessey Mk7 plug" - used in loads of mil-spec stuff for a few decades.
Electrojumble - http://www.electrojumble.org/connect...%20%20Circular - would be worth an email.
G6Tanuki is offline
Old 1st Jun 2018, 7:13 pm   #3
NormanW
Thank you for the information. I'll contact electrojumble and see if he can help.
NW
NormanW is offline
Old 2nd Jun 2018, 9:09 pm   #4
Sean Williams
Sean Williams's Avatar
Fine Thread, Plessey Mk 4. I do have a reasonable stock if you get stuck
Sean Williams is offline
Old 3rd Jun 2018, 5:21 am   #5
NormanW
Thank you, the extra information helps. I'll PM you when I get a bit closer to needing them.
NW
NormanW is offline
