25th Mar 2018, 2:59 pm | #1 |
What is this? Electric bed warmer? (Identified as a degaussing coil).
I found this left behind in the loft of an house I recently bought. My best guess is that it's an old electric bed warmer, but I'm not convinced. It has a partial label on it which I can't read clearly, and a model number of SK321. Can anyone shed any light on it?
25th Mar 2018, 3:05 pm | #2 |
Re: What is this? Electric bed warmer?
It looks like something from the 30s, but the Rank logo and the brown/blue cable suggests a much later date, maybe the 70s. That's very late for a bed warmer, as they were mostly superseded by electric blankets in the 50s.
If it is indeed a bed warmer then it's a useful thing to have - you can use it as the basis of a heated propagator for your garden plants. I'd advise an RCD though. |
25th Mar 2018, 3:06 pm | #3 |
Looks like a degaussing coil.
For ID only: https://picclick.co.uk/Vintage-Redif...l#&gid=1&pid=3 Lawrence. |
25th Mar 2018, 3:19 pm | #4 |
Well spotted. The coil certainly doesn't look like a heating element.
25th Mar 2018, 3:36 pm | #5 |
Aha, that seems to solve the riddle, thank you. The wiring was also making me doubt the apparent age of it. It doesn't appear to work, sadly.
What would it have been generally used for in a domestic environment? The previous house owner was an elderly lady who retired in the early 70s. I inherited the house with all the contents and she had no TV. A couple of lovely old Hacker radios but that's about it for electronics, so it seems a fairly odd thing for her to have owned. |
25th Mar 2018, 3:40 pm | #6 |
Rank degaussing coil for sure, I have one.
John Joe. |
25th Mar 2018, 3:53 pm | #7 |
The label seems to specify a maximum duty cycle (30 seconds in 5 minutes?), which would be more appropriate for a degaussing coil than a bed warmer .....
25th Mar 2018, 5:06 pm | #8 |
They were mostly used by TV service engineers, so it's not clear how it ended up in your house.
25th Mar 2018, 6:10 pm | #9 | |
The dymo label says SK321. I am pretty sure that is the region (SK) and depot number (321) I sure hope nobody is homing in on anything I might gave "liberated" back in the day!
-- Graham. G3ZVT Last edited by Graham G3ZVT; 25th Mar 2018 at 6:40 pm. |
25th Mar 2018, 7:07 pm | #10 |
Left behind on a service call?
25th Mar 2018, 10:16 pm | #11 |
Re: What is this? Electric bed warmer? (Identified as a degaussing coil).
I spotted the "granada" plug, it also depends on what her husband did, I'm an electrician and I've loads of weird and wonderful things that people have given me, "you may be able to use this" is the common one as they hand you something totally useless. The trouble is if you refuse something they may not offer you something that could be handy because "you didn't want the last thing I offered you".
25th Mar 2018, 11:37 pm | #12 | |
My guess is that it was left behind by a visiting TV engineer who never came back to collect it. The old lady put it away in the loft just in case someone asked for it back, but they never did. The TV could have been rented from Granada and taken back by them or disposed of before you bought the house. You could always offer it in the For Sale section here. A vintage TV restorer might want it, though it's not highly valuable. |
25th Mar 2018, 11:49 pm | #13 |
If you still have a CRT monitor, you could try bringing it close to the screen when it is running. By accident I found that the magnet of the speaker a Sony portable radio was strong enough to change the colour of mine a few years ago, necessitating using the degauss function of the monitor to get it back to normal.
26th Mar 2018, 10:24 pm | #14 |
If my memory serves me right the switch shown had a biased toggle so that after switching on and degausing the crt the switch was released so springing back to the off position and switching off the coil.They worked very well provided you remembered to switch off well away from the crt otherwise you were back where you started.They were around in the early seventies.Peter.
26th Mar 2018, 10:37 pm | #15 |
I can remember a TV engineer who put one down on the bench the wrong way up.
It it began to fill the workshop with smoke. |
31st Mar 2018, 3:46 pm | #16 |
Definitely a degaussing coil. Used one on Colour CRT sets when I was at Rediffusion NE Ltd. Ours had a self cancelling toggle switch that cut the power when you let the switch go. I can remember doing a "Manual Assist" in a house in Newton Aycliffe. We were going to take the set back to the workshop. But the "Loan" set showed the same symptoms. Then we realised the set was next to a steel radiator. A degauss of that got some very weird looks from the customer, but it did the trick. Degauss of their set and the service call was done.
28th May 2018, 8:19 am | #17 |
I'm the proud new owner of the degaussing coil which PencilMatt describes above.
Does anyone know what the metal buttony-thing on the outside is? As far as I can make out it isn't a switch, but if it isn't a switch then what is it? You can't press it in and it doesn't seem to turn. What puzzles me is that if it isn't meant for some kind of user intervention then why is it mounted on the outside of the case? Can post more pictures if required. Thoughts appreciated! Thanks Steve |
28th May 2018, 11:14 am | #18 |
The button is the push to make switch.
It is only supposed to operate for 10s of seconds. They burn if you power them for too long. |
29th May 2018, 6:49 am | #19 |
Thanks - based on your info I took a closer look - it was actually a momentary toggle switch with the toggle missing (the toggle lever goes through the slot in the top).
Have ordered a new switch (not easy to find a replacement as there is only 13mm clearance in there plus a new fuse holder (old one corroded) and will see if I can get it up and running. |
29th May 2018, 9:17 am | #20 |
The one I had was a biased toggle switch, that broke after many years and required replacement.
Frank |
