Old 30th May 2010, 5:19 pm   #1
ray1234
Default R1155 Power Supply
I need to build an external power supply for a R1155. The set is mostly unmodified so the power has to go in via the Jones connectors. Advice and a circuit diagram would be much apreciated.
Ray
ray1234 is offline
Old 30th May 2010, 5:26 pm   #2
HamishBoxer
HamishBoxer's Avatar
Default Re: R1155 Power Supply
Yes the important thing on these R1155s is that negative HT is NOT earthed.Not sure wether there has been a circuit on the forum before,worth searching also an excellent book from Australia gives full o/haul details.
David GM8JET
HamishBoxer is offline
Old 30th May 2010, 5:45 pm   #3
ray1234
I agree and I'm not at all sure that I fully understand the R1155's power requirments. Negative voltage is a bit beyond my understanding. I will search for the book.
ray1234 is offline
Old 30th May 2010, 5:57 pm   #4
HamishBoxer
What normally happens except on 1155 is that the High Voltage (+ and -).The - negative side would go to chassis but on these it is isolated from the chassis.In other word the negative is above earth,sure there must be a better way of putting it.Also Chas E Miller of The Radiophile does a good little cheap book (£5 or less) amongst others on the 1155 ,not sure wether it covers power supply or not.
Old 30th May 2010, 5:59 pm   #5
HamishBoxer
If you get stuck feel free to PM me and i will come up with what i can.Have a 1155 myself.Unlikely though you can just plugin and it work as for one thing the rubber wiring perishs and shorts stuff out.
Old 30th May 2010, 6:39 pm   #6
Radio_Dave
Radio_Dave's Avatar
Hi Ray,
Did you notice the PSU I made for my R1155 here https://www.vintage-radio.net/forum/...ad.php?t=53805 I've also attached a picture of its innards below
It's just a simple MDF box. The HT is supplied from a 240V 100mA transformer using a Si bridge rectifier, a choke and 330uf 450V capacitor takes care of smoothing. DC output is 210V.
The LT is supplied from the big 6.3V 6A transformer on the right. The amplifier is a LM386 and it's powered from an unused 24V secondary, via a LM317 voltage regulator.
HTH
Radio_Dave is offline
Old 30th May 2010, 9:24 pm   #7
glowinganode
glowinganode's Avatar
...not below?
p.s. nice job Dave on the p/s, followed the thread when you were deciding on which transformers to use, but hadn't seen the end result up till now.
Rob.
We have done so much, for so long, with so little, we are now qualified to do anything with nothing.
glowinganode is offline
Old 31st May 2010, 5:51 pm   #8
AC/HL
AC/HL's Avatar
These pages from the manual give you some idea why the HT- must not be connected to the chassis in this receiver.
AC/HL is offline
Old 1st Jun 2010, 11:55 am   #9
G4XWDJim
G4XWDJim's Avatar
Ray1234,
Hope this helps. It's from a 1946 Wireless World modification sheet.
Good luck,
Jim
G4XWDJim is online now
Old 1st Jun 2010, 4:23 pm   #10
ray1234
Gentlemen
Thank you for all your replies. May problem now is downloading the pdf files some of you kindly posted. On download the PDF's turn into PHP, any ideas on why? Or how I can open them?
Ray
ray1234 is offline
Old 1st Jun 2010, 4:31 pm   #11
Dave Moll
Dave Moll's Avatar
They all work fine for me. What browser are you using?
Dave Moll is online now
Old 1st Jun 2010, 4:36 pm   #12
ray1234
IE7
Ray
ray1234 is offline
Old 1st Jun 2010, 5:37 pm   #13
GMB
GMB's Avatar
Just click the links.
Don't do "save link as..." as the links are not direct links to the PDFs.
GMB is offline
Old 3rd Jun 2010, 12:50 am   #14
Radio_Dave
Radio_Dave's Avatar
Hi Ray,
As promised here's the circuit of my PSU/amp. I reckon it's about as simply as it can be made. It's made on matrix board, inside a MDF box, so there's no worries about the HT-ve and chassis/earth arrangement of the R1155.
I made the circuit around two transformers that I already had. If you use different transformers, you'll have to make some alterations. Just remember, if your R1155 has a full compliment of valves, you will need a HT supply of 100mA and a LT supply of at least 5A
HTH
Edit: See post 23 for the circuit diagram
Old 3rd Jun 2010, 11:35 am   #15
ray1234
Dave
Now that makes perfect sense. Thank you ,and everyone, for your help and advice
Ray
ray1234 is offline
Old 20th Oct 2012, 8:25 pm   #16
ThePillenwerfer
ThePillenwerfer's Avatar
The full article can be found here: http://www.vintageradio.me.uk/military/1155_ww1946.htm
- Joe
ThePillenwerfer is offline
Old 21st Oct 2012, 7:03 pm   #17
Keith
Keith's Avatar
The 3 section HT filter in the article would be a bit OTT today. A throwback to a time when 16uF was a large value capacitor!
Keith Yates - G3XGW
VMARS & BVWS member http://www.tibblestone.com/oldradios/Old_Radios.htm
Keith is offline
Old 21st Oct 2012, 7:38 pm   #18
Keith
Keith's Avatar
The downside of this WW article was the advice to remove the DF valves to save on heater current. What happened to all those VR102's? They are now sufficiently scarce/desirable to be snapped up on Ebay at around £50 each! I suspect the audiophools...
Keith Yates - G3XGW
Keith is offline
Old 21st Oct 2012, 7:53 pm   #19
M0FYA Andy
Has anybody ever come across any other radio which used the VR102, or its civilian equivalent, the BL63?
Andy
M0FYA Andy is online now
Old 22nd Oct 2012, 12:19 pm   #20
HamishBoxer
Try £62.50 plus postage!
