Old 19th Jan 2020, 11:52 am   #1
skodajag
Default Crimping dial cords
Restringing dial cords is rarely easy, and one of the most difficult tasks is making the knots to connect the cord to to the tension spring. Sometimes though instead of a knot the cord is crimped, which would be much easier if one had access to the right crimps and possibly the correct crimping tool. Any suggestions?
Keep Calm and Carry On Restoring
skodajag is offline
Old 19th Jan 2020, 12:09 pm   #2
Alistair D
Alistair D's Avatar
Default Re: Crimping dial cords
Search Ebay for jewellery making crimps. The tools are also available on Ebay.
Al
Alistair D is offline
Old 19th Jan 2020, 1:39 pm   #3
skodajag
Perfect. Thanks.
skodajag is offline
Old 19th Jan 2020, 2:37 pm   #4
Boulevardier
"one of the most difficult tasks is making the knots to connect the cord to to the tension spring."
I find the easiest way is form a loop through the "eye" of the spring, put in a few twists, and seal the twist with a blob of superglue.
Mike
Boulevardier is offline
Old 19th Jan 2020, 2:45 pm   #5
My way is to do a single overhand knot, pull 'till it is the right tension and mark with a felt pen (held in teeth). Slip the cord off something so it goes slack, then you can make a proper reef knot with no tension in the right place. Put cord back on and viola!
Old 19th Jan 2020, 2:52 pm   #6
Graham G3ZVT
Graham G3ZVT's Avatar
I find it "helpful" to imagine how many sets the ladies in the factory could have strung, in the time I am struggling to position a single knot...
Graham.
G3ZVT
Graham G3ZVT is offline
Old 19th Jan 2020, 3:08 pm   #7
poppydog
I get my misses to tie the knots for me, its surprising how delicate the "iron fist in the velvet glove" can be..
poppydog
poppydog is offline
Old 19th Jan 2020, 3:09 pm   #8
Julesomega
Julesomega's Avatar
I love the professional feel of anything crimped and I recently bought a circular crimping tool to crimp ferrules. The crimper probably came from Banggood in China, the plain ferrules from eBay. (If you buy from Banggood set up an account first so that you get the full guarantee service)
Use the smallest practical ferrule diameter, they will crimp down literally to zero diameter
ID:	197405   Click image for larger version
- Julian
It's good here
Julesomega is offline
Old 19th Jan 2020, 3:24 pm   #9
Nuvistor
Nuvistor's Avatar
Probably find the string was made up to the correct length and knotted using a jig before it got anywhere near the radio.
Frank
Nuvistor is offline
Old 19th Jan 2020, 3:24 pm   #10
ionburn
ionburn's Avatar
I have never used them for other than the stainless steel wire intended for (not in the original application) but I have some crimps that are used for stainless steel wire used in fishing. It might be worth a look to see if they are suitable (possibly too small but I have not checked)?
ionburn is offline
Old 19th Jan 2020, 3:40 pm   #11
Alistair D
Alistair D's Avatar
This thread about knots may also be useful.
https://www.vintage-radio.net/forum/...d.php?t=142721
Al
Old 19th Jan 2020, 4:02 pm   #12
David G4EBT
David G4EBT's Avatar
I believe that dial cords were originally tied with a knot called the 'perfection loop'.
A technique which I've yet to master!
Name:	Dial cord perfection loop.jpg
David.
BVWS Member.
G-QRP Club member 1339.
David G4EBT is online now
Old 19th Jan 2020, 6:04 pm   #13
crackle
That looks exactly like a Bowline knot, designed to tighten with more pressure applied.
You can also try a Blood knot, which can also be used to tie onto a ring.
Mike
crackle is offline
Old 19th Jan 2020, 6:32 pm   #14
Boulevardier
On this topic, is anyone able to direct me to a source of "traditional" tuning cord? I have tried fishing line (to avoid stretchability), and it doesn't grip properly on plastic pulleys. Haven't yet tried abrading the surfaces, but better to get the proper stuff.
Mike
Old 19th Jan 2020, 6:50 pm   #15
DonaldStott
DonaldStott's Avatar
Try here: -
https://www.bendijkman.nl/index.php?...oduct&ipath=16
Ben also provides this advice: -
https://www.bendijkman.nl/how-to-kno...ord-2?ipath=16
BVWS Member
DonaldStott is offline
Old 19th Jan 2020, 7:09 pm   #16
Boulevardier
Thanks for that Donald. Looks perfect, but I can't see any way of actually placing an order on their website!
Mike
Old 19th Jan 2020, 10:31 pm   #17
emeritus
You could try whipping twine, which you should find in a yacht chandlers. It is inextensible and available in waxed polyester in a variety of diameters and colours, usually on 3" spools.
emeritus is offline
Old 20th Jan 2020, 10:49 am   #18
DonaldStott
Hi Mike - just send Ben an email and he will explain how to place an Order - it's not a commercial operation.
Info@bendijkman.nl
BVWS Member
Old 20th Jan 2020, 11:54 am   #19
crackle
I can also recommend waxed whipping twine
Mike
crackle is offline
Old 20th Jan 2020, 4:50 pm   #20
Test Desk
In a previous existence, I used a similar tool to crimp the centre connector of a thin coax called RG179 which was widely used by Cable TV companies to interconnect 2mbs to multiplexer mountains up to 140mbs. The pins were very easy to bend if you weren't careful.
Test Desk is offline
