Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Other Discussions > Forum Announcements and Comments
Forum Announcements and Comments Announcements about forum changes will be made in this section. All new threads here now require moderator approval.
Old 23rd Mar 2012, 10:12 pm   #1
ITAM805
ITAM805's Avatar
Default uploading schematics
I've tried to upload a couple of readable sized schematics as Gifs and/or mono bitmaps, both under the 200k forum limit, but they always get downsized to an unreadable 50k or so. Am I doing something wrong?
Thanks
ITAM805 is offline
Old 23rd Mar 2012, 11:24 pm   #2
Red to black
Red to black's Avatar
Default Re: uploading schematics
You can send them as Zip files ( you need to zip them), or as I do, if you can create a Pdf. to get around the forum resizing software.
I hope this helps.
Red to black is online now
Old 23rd Mar 2012, 11:40 pm   #3
Robert Darwent
Robert Darwent's Avatar
Image files have to be no greater than 200 kB AND not exceed 800 x 600 pixels (width x height) otherwise the forum software resizes them.
As already suggested, the easiest solution is to post them zipped or as a pdf if they exceed any of the limits.
Regards
Robert G0UHF
www.wavesintheair.co.uk
Robert Darwent is offline
Old 24th Mar 2012, 10:30 am   #4
ITAM805
ITAM805's Avatar
Thanks Baz and Robert, it's the layout size that tripped me up. The cd pages are in PDF format, but although my software, Foxit reader allows me to copy single pages it doesn't let me save them as PDF's!
ITAM805 is offline
Old 24th Mar 2012, 10:55 am   #5
julie_m
Can't you just select "PDF file" as your default printer, and "print" out just the pages you want from the PDF viewer, giving you a PDF with only the wanted pages in it?
That's how it's done in Linux, anyway.
julie_m is offline
Old 24th Mar 2012, 1:21 pm   #6
Robert Darwent
Originally Posted by ITAM805 View Post
...Foxit reader allows me to copy single pages it doesn't let me save them as PDF's!
If you just wish to post single pdf pages that have been copied as an image format (jpg, gif, etc) to the forum, there is no need to convert them back into pdf's again to do so.
Just right click on your image file, then 'Send to' > 'Compressed (zipped) Folder' and upload the resulting zipped folder to your post. The directions are for Windows XP, other Windows versions should be basically the same.
Zip folders have a 1.91 MB limit on the forum and no constraints on the pixel size of the image which has been zipped inside.
Regards
Robert G0UHF
Old 28th Mar 2012, 12:58 pm   #7
ITAM805
ITAM805's Avatar
Thank AJS and Robert for the most useful tips.
ITAM805 is offline
