Websites Found an interesting website? Post the details here and share it with the rest of us. Please stick to websites that are in some way related to our hobby/interest. |
18th Apr 2019, 11:01 pm | #1 |
Restoration of Apollo era consoles
Here's a snippet from a website if you've ever wondered what the Mission Control consoles looked like inside. They're being removed here for 'restoration' into a simulated display for visitors to the control room.
http://www.collectspace.com/news/new...storation.html
Kevin |
19th Apr 2019, 12:36 am | #2 |
Re: Restoration of Apollo era consoles
Very cool. Have always wondered about that. Thanks for posting.
19th Apr 2019, 2:08 am | #3 |
Of course, they'll be full of cigarette ash.....and a bit of cigar ash from the good times .
B
19th Apr 2019, 7:36 am | #4 |
Ah, the good old days before smoking was bad for you! I remember the SA desks at the BBC always included an ashtray…
19th Apr 2019, 7:46 am | #5 |
No Longer a Member
I've always thought it highly likely that the video monitors in those units were made by Conrac, but I cannot quite see the chassis labels well enough in the photos. If they are another brand I would be interested to know who, possibly RCA or Motorola. Conrac dominated the high reso monitor market. They had very well focused high intensity beams and clearly a high video bandwidth to display not only video images but also Telemetry data and most had P4 phosphors from the historic photos I have seen. Also I have thought it likely the CRT in them was probably the 14BAP4, from the look of the rectangular face, but I'm not sure if they were a bigger size. Those monitor chassis would be easy to get working again and probably most of those CRT's are still ok.
19th Apr 2019, 8:21 am | #6 |
The 7th photo shows the rear of a console.
At first I thought it contained Coax cable but now it looks more like pneumatic tubing. What is that tubing for? Could it be part of a fire suppression system? |
19th Apr 2019, 8:34 am | #7 |
Very interesting.
I like the badge patch too, very good that. I can decipher all the images apart from the grid squares panel on the right. What do you think that signifies?
David, G4YVM. |
19th Apr 2019, 10:34 am | #8 |
Indicators, as can be seen in the background immediately above the badge?
David |
19th Apr 2019, 11:48 am | #9 |
the crt monitors are Astronautics Corporation, Wikipedia has an article on them, they specialise in glass cockpits these days and were early pioneers of aerospace display systems.
Some of the consoles had lamson-tube systems, but from what I can glean, the small pneumatic systems were for the digit displays, which used air-operated backlit plastic slides to display each numeral, driven by the RTCC computers of course. The Houston mission control centre was designed by a Welshman.. Tecwyn Roberts, though a lot of contractors put it together, the major ones being Singer and Philco, AFAIK (ref. Failure is not an option, Krantz)
Kevin |
19th Apr 2019, 2:14 pm | #10 |
No Longer a Member
19th Apr 2019, 9:42 pm | #11 |
A bit of a google earlier showed alot of these monitors being sold off, at fixed prices of between $700-800 depending on provenance.
The monitors were originally valve state but upgraded to solid state during the Shuttle programme. The restoration of the consoles (which are meant to be switched on for long periods for visitors) has included getting rid of the crt monitors and fitting LCD panels to custom re-manufactured bezels. I wouldn't be surprised if they weren't classified drawings if they were involved in aerospace, I believe astronautics developed crt displays in early fighter jets. (might have read that in wikipedia, I forget). The data shown on these old displays was a hybrid video picture generated by a video camera in a back room. Numerical data from a mainframe text display was combined optically with transparencies to generate lines, borders, headers and labels for the parameters, since that was beyond the capability of the computers during Apollo. Console button-selections would not only call up a different computer screen but also shifted the correct overlay into position from a motorised magazine. No expense spared!
Kevin Last edited by McMurdo; 19th Apr 2019 at 9:47 pm. |
19th Apr 2019, 10:14 pm | #12 | |
No Longer a Member
Recently I subjected a vintage Avionics video monitor to study, with the same type of rectangular CRT face as those NASA monitors. One of the reasons I got these monitors is because they reminded me of the NASA monitors. Wouldn't you know it, I had to copy out the schematics by hand before I could power them and use them. They contained a number of innovations in their construction, one being an astonishingly clever & efficient video black level clamp not seen in domestic video monitors, which I found out in the end was actually designed by Tektronix in the 1960's, the story is here: http://worldphaco.com/uploads/The_19...o_monitor..pdf looking at the rear of those NASA monitors, the deflection yoke looks like it might the the same/similar precision type made by Syntronic Instruments, there is a photo of one in the article, these are much better made than the average yoke. |
20th Apr 2019, 12:18 pm | #13 |
Nasa monitor chassis
Kevin |
20th Apr 2019, 12:58 pm | #14 |
Although it may be obvious, considering the title of this thread, it might be worth mentioning that these are not the original monitors, used for Apollo, which each had 2 numeric indicators in the top right.
https://spacecenter.org/restoring-ap...ssion-control/ My experience of 5 Conrac monochrome monitors made in the late 70s is that they never failed although the tubes were past their best after running 24 hours a day, 7 days a week, about 51 weeks per year for almost 20 years. It is too bad that the restoration is not being done with CRT monitors. They might outlast any modern display. David |
20th Apr 2019, 1:12 pm | #15 | |
No Longer a Member
Do you know anything about the original Apollo monitors, were they Conrac? I agree, to call it a "restoration" when they are basically getting replaced with modern computer screens is a bit of a stretch...it is just for tourism & entertainment for joe public it seems. I think they should restored as they are, and if necessary use money from the "fund raising" to build a CRT rebuilding plant to keep them working indefinitely ! |
