Old 8th Nov 2018, 5:30 pm   #1
Tom williams
Tom williams's Avatar
Default Mystery heater?
My nan has this heater that is made by Electrical Industries of Ireland Limited and I don't know much about it other than the brand, if anyone can help that would be great.
Tom.
ID:	172469   Click image for larger version
ID:	172470   Click image for larger version
Tom williams is offline
Old 10th Nov 2018, 1:58 am   #2
Phil G4SPZ
Phil G4SPZ's Avatar
Default Re: Mystery heater?
It’s similar to many ‘one bar electric fires’ made over the 1940-1960 decades. Yours looks in good condition, and well designed with an effective guard.
However please bear in mind the fact that such appliances will never meet modern electrical safety regulations! You might encourage your Nan to get it checked for safety. It should still pass a modern Class I PAT test.
Phil
Phil G4SPZ is offline
Old 10th Nov 2018, 9:54 am   #3
Brigham
Another one heading for the dustbin.
Electrical Industries of Ireland Limited doesn't ring any bells, but I would guess at a company building local versions of an existing item, for the benefit of jobs and the economy.
Rover cars were built in Dublin under a similar arrangement.
Brigham is offline
Old 10th Nov 2018, 10:00 am   #4
Paul_RK
Paul_RK's Avatar
I'd guess at the '70s for this one's age, from the general look of it plus the foil label with British Electrical Approvals Board kite mark. Probably safe enough so long as the cable isn't under strain or fraying, the main danger with these comes if they're knocked over when nobody's around, anything gets draped over them, etc. Best kept out of the bathroom too of course.
Paul
Paul_RK is online now
Old 10th Nov 2018, 6:26 pm   #5
McMurdo
McMurdo's Avatar
you can of course still buy them.
If it's BEAB approved then it's been through some pretty strict safety tests which include clothing etc draped over and timing how long it takes to ignite. The requirements are covered in the Which? tests.
Kevin
McMurdo is offline
Old 10th Nov 2018, 7:03 pm   #6
Paul_RK
Paul_RK's Avatar
Yes, the spacing between the bars may be the main thing that wouldn't be permitted in a new heater: much wider on Tom's than on that one.
Old 10th Nov 2018, 7:45 pm   #7
Phil G4SPZ
Phil G4SPZ's Avatar
I also think - though it’s hard to tell from the photo - that the elements in the ‘new’ heater are sleeved in quartz glass, rather than being open wound with bare wire.
It was by using a mains neon tester screwdriver and an open-wire bar fire as a schoolboy that I learned about potential dividers and neon striking voltages...
Phil
Old 10th Nov 2018, 8:23 pm   #8
OscarFoxtrot
OscarFoxtrot's Avatar
Glass sleeved elements are still treated as live for the purposes of inserting a British Standard Test Finger (BS 3042:1971)
OscarFoxtrot is offline
Old 12th Nov 2018, 10:45 am   #9
Brigham
Quartz tube elements are a different technology. They are hollow, and take a spiral-wire of
the bowl-fire type, stretched out.
I've not yet met a round bar element with a quartz tube as well.
Brigham is offline
Old 15th Nov 2018, 11:27 am   #10
OscarFoxtrot
Yes, but for touch safe requirements quartz tubes are treated as though they were wire spirals.
Old 20th Nov 2018, 10:47 pm   #11
Tom williams
The plug on it is a bs 1363 with unsleeved pins and a 13 amp fuse, the plug gets quite warm when both bars are in use and not so warm a only one is in use
Old 20th Nov 2018, 11:42 pm   #12
teetoon
Hi Tom, if you are worried about the plug getting warm, I would have a look inside and make sure the screws are not loose and check the fuse holders. If you remove the fuse and squeeze the forks together slightly then the fuse will make a better connection.
It could also be the socket you are using is old and not gripping the pins as well as it should.
It is quite common for 13 amp plugs to get warm with loads of 2 Kw or more but they shouldn't be hot.
David.
teetoon is offline
Old 21st Nov 2018, 5:48 pm   #13
Tom williams
The socket used is a modern MK 2 gang switched with neon and I think it is a two KW heater.
Old 31st Dec 2018, 4:37 pm   #14
Tom williams
David.
No need to worry anymore, it's gone to heater heaven😥😥😭😭
