Old 18th Dec 2017, 4:34 pm   #1
Default New Magneta 36 (PO 36) clock power supply.
I have made a new, completely over the top, power supply for my Magneta master clock which runs a few dials over the house too. The supply did develop a fault soon after introducing it, see https://www.vintage-radio.net/forum/...04#post1000804
Now working well, the meters are top to bottom...
Various voltages, Hipp supply (5V), dial supply (15V), sync/system/battery at 21V and the input to the regulators (about 33V).
Fast/Slow meter, using MSF and the one minute pulses from the 60 second wheel.
Various currents, 5, 15 and 21V plus battery which is a centre zero.
Below is the three 6V sealed lead acid batteries for backup, float charged at 21V with switch and fuse, I put negative to the switch body so I can measure the battery voltage to the fuse.
The synchroniser is pulsed (again from MSF) at 8 and 2 am/pm to reset the 30 second pulse wheel, this is done twice with a six second gap to stop the +/- one second error a single pulse can give to a synchroniser depending upon which way it is corrected.
All jolly good fun, very OTT and very pretty.
Old 18th Dec 2017, 4:40 pm   #2
M0FYA Andy
Default Re: New Magnata 36 (PO 36) clock power supply.
Excellent.
Can you give some details of the MSF to synchroniser circuitry, please?
I have a PO36 with a synchroniser which I really should get running.
Many thanks,
Andy
M0FYA Andy is offline
Old 18th Dec 2017, 5:13 pm   #3
Default Re: New Magneta 36 (PO 36) clock power supply.
It's done with a PIC and an MSF receiver, you should be able to work out how to wire it from the source code, would you like that by PM? I have found some MSF receivers too if one would be of use.
Old 18th Dec 2017, 9:53 pm   #4
M0FYA Andy
I've no experience of PICs, and have too many other projects to find time to learn, so thanks but I'll pass on that one!
I do have a unit which I bought years ago from chap in Holland which is supposed to do the whole job, I really ought to get it working!
Andy
