11th Aug 2004, 6:40 pm | #1 |
Isolating transformer questions
I keep wondering whether to buy an isolating transformer for safety reasons. However I dont really understand how this item provides protection. I assume it's only needed for ac/dc sets? Everybody always says use an isolating transformer but nobody ever says why! Can somebody please explain David
http://www.youtube.com/ My Nixie Clocks |
11th Aug 2004, 7:10 pm | #2 |
Re: Isolating transformer questions
An isolating transformer allows you to earth the chassis of the set being worked on, even if it's a transformerless set. This is inherently safer (no chance of a live chassis by mistake) and allows the use of earthed test gear like signal generators and scopes.
Opinions differ as to how important an isolating transformer is. It all depends on the environment you work in and whether you use test gear a lot. Needless to say, if you *don't* use a transformer you need to be very, very careful about mains polarity. HTH, Paul |
11th Aug 2004, 7:21 pm | #3 |
HiPaul,
Earthing the chasis makes sense but what, if any, protection would I have from electrocution? Thanks David
11th Aug 2004, 7:25 pm | #4 |
If you have a AC/DC set, then the chassis is connected to one side of the mains. If it's the live side then the whole chassis is live. I'm sure that most forum members have been caught somewhere and lived to tell the story. My initiation was on a Bush TV80 " portable " TV when I was about 15 years old. I knew to test the mains polarity with a neon screwdriver but somebody had bridged out the neutral side of the mains switch. I turned off the set and touched the chsssis. Only once.
Actually I think all kids ought to get an electric shock at some point fairly early on just to prove to them that electricity is dangerous if you do the wrong thing. The only problem is that we might kill a few by mistake. It's called un-natural selection! |
11th Aug 2004, 7:48 pm | #5 | |
Even with an isolating transformer, if you grab hold of mains live with one hand and the chassis with the other, there's a good chance you'll die. An old repairman's trick was to work with one hand in your pocket. Best regards, Paul Last edited by Paul Stenning; 26th Dec 2004 at 8:45 pm. Reason: Fix link or code for vBulletin |
11th Aug 2004, 7:55 pm | #6 |
Thanks Paul you've answered all I needed to know
11th Aug 2004, 8:02 pm | #7 | |
Hi All
Yes high voltages can be dangerous in more ways than one.
Chris C G8TJR Last edited by Paul Stenning; 26th Dec 2004 at 8:49 pm. Reason: Fix link or code for vBulletin |
11th Aug 2004, 9:20 pm | #8 |
The main advantage of an isolating transformer is as Paul said, the ability to used earthed test equipment. Also you don't need to worry about what way round the chassis is connected on AC/DC sets (or those run from autotransformers or 'heater transformers' like some 'midget'sets are).
In isolation transformer will NOT prevent electrocution but reduces the risks. Rich.
There are lots of brilliant keyboard players and then there is Rick Wakeman..... Last edited by Darren-UK; 26th May 2007 at 12:25 pm. Reason: Deleted ref to an early thread which no longer appears to exist. |
12th Aug 2004, 9:36 am | #9 |
I would say that the only advantages of an isolating transformer are for use with earthed test equipment, that it might limit the maximum short current in the event of a problem and that it isolates you from mains neutral - which can become momentarily dangerous when some (other) appliance decides to blow a fuse. If you joined earthed test equipment to mains neutral you might find a lot of current flowing between them and a house RCD would probably trip.
There are disadvantages. It may lull you into a false sense of security and it prevents any RCDs that might be on the mains side from helping you. The point is that if you allow one side of the isolated output to be joined to mains earth then the live terminal has EXACTLY the same lethality as the original mains did. |
1st Sep 2004, 11:19 am | #10 | |
Hi All,
Being new to your forum, I don't know if it is appropriate to ask a question here, or whether I supposed to start a new thread, but I MUST CLARIFY the following: I thought I understood the correct use of isolating transformers until I read this here: Quote:
Regards Andrew Last edited by Paul Stenning; 26th Dec 2004 at 8:47 pm. Reason: Fix link or code for vBulletin |
1st Sep 2004, 12:08 pm | #11 |
RCDs do not detect short circuits or overloads. They sense the difference betweenthe currents flowing in the live and neutral wires. Any difference is assumed to be a fault, possibly current flowing through your body.
Any fault on the output side of an isolating transformer cannot unbalance the live and neutral currents at the primary so an RCD in the primary circuit cannot give any protection. An RCD in the secondary circuit can give no protection unless one side of the secondary is earthed before the RCD. THis is a rather odd way to use an isolating transformer and rather defeats the purpose. The HT on an AC set with a mains transformer is always potentially dangerous. An RCD will not save you as the HT is on the secondary of an isolating transformer. In this case the transformer is in the set, not external, but the idea is the same. THe main purpose of an isolating transformer is to ensure that the chassis on an AC/DC set is not at mains live. There is no substitute for being aware of the risks and taking due care. |
