22nd Jan 2020, 6:16 pm | #1 |
Tantalum ESR?
H folks
a simple question, can one measure a Tantalum cap for ESR like you would an electrolytic? Thanks |
22nd Jan 2020, 6:26 pm | #2 |
Re: Tantalum ESR
Yup.
Because of ther non-wound construction you can find quite low ESL and ESR values from a good one. However, it's been found that one way to dispatch the little devils to the afterlife is to use this low impedance to carry high ripple or surge currents. It's recommended to use them in series with a current limiting resistor which neatly removes the low-Z advantage :-( David
22nd Jan 2020, 8:15 pm | #3 |
Re: Tantalum ESR
Many thanks David
22nd Jan 2020, 8:34 pm | #4 |
Re: Tantalum ESR
If you want to experiment with some tants I offered some FOC but after 2 pm's no response so your welcome to play.
Cheers Mike T
22nd Jan 2020, 11:14 pm | #5 |
Re: Tantalum ESR?
Beware, though, if you feel tempted in your experiments to try one with reverse polarity to watch it go up, the yellow-green staining they create is the very devil to shift.
23rd Jan 2020, 11:12 am | #6 | |
Re: Tantalum ESR?
23rd Jan 2020, 6:27 pm | #7 |
Re: Tantalum ESR?
You can measure ESR, but if it measures correctly the tantalum can be short circuit as well, so when testing, always use a dc ohm measurement as well.
