Old 10th Mar 2020, 10:19 pm   #21
fetteler
fetteler's Avatar
Default Re: Zx81
Thank you.
That looks very much like like hum on the video to me - i.e. there is a 50/100Hz waveform superimposed on the video output. Try powering the ZX81 from a battery...
Steve.
fetteler is offline
Old 10th Mar 2020, 10:26 pm   #22
John Earland
Default Re: Zx81
Originally Posted by fetteler View Post
Please check that the DC coming from the power supply is the correct voltage and is smooth?
Also a photo of the 'wobbly' text you describe would be helpful
The voltage was 14v - seemed steady though I don’t know if it’s smooth because I don’t have an oscilloscope.
John Earland is offline
Old 10th Mar 2020, 10:28 pm   #23
John Earland
Default Re: Zx81
Thank you.
Steve.
That’s a great idea! Will do and I’ll let you know-thank you.
Old 10th Mar 2020, 11:09 pm   #24
SiriusHardware
Default Re: Zx81
The heavy diagonal black bars in the picture are presumably just artefacts caused by the TV frame rate and the camera refresh rate interacting. I would imagine they are not present when viewed with the Mk1 eyeball, is that right?
Unfortunately those artefacts are so prominent they make it a little bit difficult to see the effect you are really trying to portray.
That buckled, washed out effect is what I would expect to see if I was tuned to the edge of the signal or the wrong side of the signal rather than the centre of it. You've definitely tuned manually, in very small steps, all the way across the signal from one side to the other?
SiriusHardware is offline
Old 10th Mar 2020, 11:41 pm   #25
John Earland
Default Re: Zx81
Hi-yes those artefacts can’t be seen by the naked eye. I did fine tune it the best I could and this was the result. It’s bang in the middle of the tuning area with the colour reduced to zero.
Old 10th Mar 2020, 11:50 pm   #26
Andrew2
Andrew2's Avatar
Default Re: Zx81
Another vote for a tuning error. It looks just like the TV needs a tweak.
Andy G1HBE.
Andrew2 is offline
Old 11th Mar 2020, 12:02 am   #27
nigelr2000
nigelr2000's Avatar
Default Re: Zx81
Are you around channel 36 because I used to pick up a similar false signal further up the band on my old ZX81 and it looked just like that washed out and pretty unwatchable but tune back down the band and it was fine
nigelr2000 is offline
Old 11th Mar 2020, 12:03 am   #28
SiriusHardware
Default Re: Zx81
What sort of tuning does that Daewoo have, John, is it twiddly wheels or knobs or on-screen tuning via the remote?
I'm wondering if you are tuned to an 'image' of the signal rather than the actual signal. Try tuning completely off the signal you are currently tuned to and keep going for some way first higher than and then lower than the signal you know about.
According to my ZX81 manual which is conveniently to hand, the signal output from the ZX81 should be on UHF channel 36. However your TV is tuned, it should give you some indication of where in the channel range you are currently tuned to.
Edit: Cross posted with nigelr2000, who is thinking along the same lines.
Old 11th Mar 2020, 12:45 am   #29
fetteler
fetteler's Avatar
Default Re: Zx81
I wasn't refering to the big diagonal lines, just the wobbly image. Having seen it though I do think SiriusHardware's suggestion of being tuned to an image is a good one and as he suggests you should have a tune through the entire band to see what you find.
I wish you well with this, there's a lot of fun to be had with a ZX81
Steve.
fetteler is offline
Old 11th Mar 2020, 7:58 am   #30
John Earland
Default Re: Zx81
Yes, channel 36 is where it is sitting. I’ve been up and down the band and this is the best slot.
Old 11th Mar 2020, 8:01 am   #31
John Earland
Default Re: Zx81
Unfortunately there are no knobs to twiddle and it’s all through the remote. I use the manual tuning to find the signal on ch 36 then fine tune it and this is the best. I don’t know what you mean re: tune to an image?
Old 11th Mar 2020, 8:45 am   #32
John Earland
Default Re: Zx81
This is the tv I have :
https://rover.ebay.com/rover/0/0/0?m...2F202881667062
Old 11th Mar 2020, 9:54 am   #33
SiriusHardware
Default Re: Zx81
An 'Image' is a false or secondary weaker signal which a receiver can sometimes 'see' on a frequency some distance away from the frequency which the signal is really on. We were thinking you might be tuned to an image signal rather than the real signal.
Can you check the 'aerial' lead for continuity?
Check that there is zero ohms between the centre pin of the TV end of the lead and the centre pin of the ZX81 end of the lead, and also check that there is zero ohms between the outer part of the TV end of the lead and the outer part of the ZX81 end of the lead.
Finally, check that there is NO connection between the inner and outer parts of the TV end plug (All measurements to be made with the lead just by itself, not plugged into anything).
Old 11th Mar 2020, 10:19 am   #34
John Earland
Default Re: Zx81
Will do-thank you. I took this this morning
Old 11th Mar 2020, 10:33 am   #35
John Earland
Default Re: Zx81
LOL! This is what I get if I apply slight pressure on the ZX81 RF input connector! Almost perfect!
Old 11th Mar 2020, 10:49 am   #36
John Earland
Default Re: Zx81
Interesting. Now when I go to type something everything disappears and all I have is a blank white screen. Unplugging it and plugging it back in and the prompt is back. When I go to type though-same thing happens. Overheating causing this? Doesn’t feel very hot.
Old 11th Mar 2020, 10:53 am   #37
John Earland
Default Re: Zx81
Okay, now it’s switching itself off and resetting to prompt all the time. I’m going to switch it off and let it cool down and try in an hour.
Old 11th Mar 2020, 11:00 am   #38
Dave Moll
Dave Moll's Avatar
Default Re: Zx81
Sounds like a loose contact to me.
Dave Moll is offline
Old 11th Mar 2020, 12:23 pm   #39
SiriusHardware
Default Re: Zx81
Possibly the connecting lead has an intermittent break in it, if so, this would usually be a break in the inner conductor of the lead just at the point of entry/exit to one of the plugs as that's where they tend to get bent around the most - also people have a bad habit of pulling them out by gripping the lead close to the plug and pulling, rather than gripping the body of the plug and pulling that.
Do you have an alternative aerial / RF lead you can try?
Old 11th Mar 2020, 12:38 pm   #40
John Earland
Default Re: Zx81
Hi, yes - same result. I have tested the ohms and all seems well with the inner and outer connections and there is no short between them.
I haven't switched it back on yet because it was almost like it was short circuiting causing it to reboot. Picture went really off signal and the prompt kept disappearing. Strange.
