Old 13th Nov 2018, 5:06 pm   #1
tamemin
Default McMichael 471 Restoration
This was my second restoration. It is a 5 valve inc power supply rectifier.
The transformer had a bad voltage change contact, the reservoir cap was really leaky. I fixed the contact and replaced the cap. So far so good.
On the main chassis, I found that most of the wax capacitors 0.1uF or higher were really leaky, so replaced those with new polyester ones. There is a screened (metalised) IF amplifier tube in there, which I found had lost it's screening, due to general rot. I found I was able to temporarily wrap it with aluminium foil, and earth, which worked!
The magic eye was pretty much worn out, which was a shame, as I was looking forward to seeing that in action.
I managed to find new old stock replacements for the EM34 magic eye and the EF39 tube.
So, with that lot in place, it was pretty much good to go.
I didn't do a lot with the cabinet, just a bit of danish oil, and I also tried to clean the speaker clock (damaging it in the process)
I'll have another go at the cabinet when I have time.
At the moment, I'm fairly happy with getting the electronics working.
Pictures attached
Tam
ID:	172769   Click image for larger version
ID:	172770   Click image for larger version
ID:	172771   Click image for larger version
ID:	172772   Click image for larger version
tamemin is offline
Old 13th Nov 2018, 5:35 pm   #2
Andrewausfa
Andrewausfa's Avatar
Default Re: McMichael 471 Restoration
Nice work. Grille cloth is a nightmare to get within these shores.
Andrew
Invisible airwaves crackle with life. Or they should do.
BVWS Member
Andrewausfa is offline
Old 13th Nov 2018, 6:41 pm   #3
vinrads
Very nice Tam I must say the EM34 look very bright indeed ,you should be able to obtain some speaker cloth in keeping with the original, keep up the good work .Mick.
vinrads is offline
