Old 12th Nov 2018, 11:28 am   #1
PortugalTV
Default Broken Bakelite radio repair
broken bakelite repair with missing piece repaired with bumpersoft filler and epoxy glue followed by high build primer adn then since it was trash anyways i painted it in a non original colour
ID:	172679   Click image for larger version
ID:	172680   Click image for larger version
ID:	172681   Click image for larger version
ID:	172682   Click image for larger version
PortugalTV is offline
Old 12th Nov 2018, 8:47 pm   #2
PortugalTV
Default Re: Broken Bakelite radio repair
Old 12th Nov 2018, 11:31 pm   #3
Tractionist
Nice work ...... looks a lot more 'Rock n' Roll' in red livery !
Red to red, black to black. Throw the switch and stand well back!
Tractionist is offline
Old 13th Nov 2018, 12:41 am   #4
Lloyd 1985
Lloyd 1985's Avatar
Nice work, I think the red works well on that set, makes the dial print stand out nicely,
Regards
Lloyd
Lloyd 1985 is offline
Old 13th Nov 2018, 8:42 am   #5
stitch1
stitch1's Avatar
Nice job and better than scrapping a nice looking set.
What is it, looks a bit Philips, but don’t think it is?
John
stitch1 is offline
Old 13th Nov 2018, 8:17 pm   #6
PortugalTV
Hi
thank you all for the kind words
yes the "hot rod" red really makes the dial stand out.. i dont like to invent on vintage radios i like to respect their originality but this time i did it just because it was a scrap set and i had nothing to loose. nobody would care about repairing it because it was so broken.
It is a siera radio wich is basically a rebranded philips
you can actually use a philips chassis inside this cabinet, they are identical
the chassis model is S270u
i recapped it and put a diode in series with the dead rectifier tube, also changed the dropping resistors and it works fine!
Old 13th Nov 2018, 10:24 pm   #7
Lovely!
Old 13th Nov 2018, 11:38 pm   #8
Andrewausfa
Andrewausfa's Avatar
Ola, nice work, I think the red looks very nice and good to see a set saved.
Andrew
Invisible airwaves crackle with life. Or they should do.
BVWS Member
Andrewausfa is offline
Old 14th Nov 2018, 9:19 pm   #9
PortugalTV
Ola Andrewausfa , merlinmaxwell and all others
here is another broken scrap radio i was given by an old repair tech
and it got saved
the brown doesnt match very well but i can always correct it later
it was broken and had burn-damage on the inside because ot the dropper resistor
it works fine after a recap ,some tubes and a new mains dropper
ID:	172818   Click image for larger version
ID:	172819   Click image for larger version
ID:	172820   Click image for larger version
ID:	172821   Click image for larger version
Old 14th Nov 2018, 9:20 pm   #10
PortugalTV
Old 14th Nov 2018, 9:21 pm   #11
PortugalTV
the bakelite was so bad that i could not polish it around the knobs due to wear of the fingers rubbing while turning the knobs so i had to sand and clearcoat the entire radio. thats why it has the glossy look
the radio is a schaub libelle but the schematic doesnt match the radio because this variation was produced for the portuguese market
the closest schematic i found to guide me through the repair was for a schaub "Viola"
viola means acoustic guitar in Portuguese
in the dial you can see 2 bands : OM and OC
Onda Média = medium wave
Onda Curta = short wave
the grille cloth is not original, it is a scrap piece from other radio i restored, i think it was from a large telefunken
