8th Nov 2014, 3:09 pm | #1 |
A252 VHF Aerial Plug(s)
The internal VHF aerial plug is missing from my Murphy A252.
Attached is a photo of the left/rear of the chassis with the VHF aerial sockets marked. One of the holes is larger than the other. Would this have been a two pronged plug or two separate plugs? If you can point me to an image that would be very helpful. I have also attached a photo of one of the superb speaker plugs. It has a central grub screw and is even inscribed L.S. Does this particular kind of plug have a name? Thanks. |
8th Nov 2014, 3:16 pm | #2 |
Re: A252 VHF Aerial Plug(s)
The plug in your photo is a Wander plug. It is an old British standard and very common on 50s British radios.
I can't help with the VHF socket. One of the holes is likely to be a Wander socket but I don't recognise the other one. You can fabricate your own plugs using automotive split pins. If you know a mechanic, ask him nicely for a selection of sizes. |
8th Nov 2014, 3:46 pm | #3 |
The smaller "Wander" plug can be replaced by one of these:
http://www.maplin.co.uk/p/maplin-4mm-plug-black-l20bh [the dedign of the springy-bit means they compress enough to fit a standard Wander-socket unlike most other 4mm plugs]. Some designs of 4mm plug will also nicely fit the larger sockets used on quite a bit of 50s/60s gear; there's a design which has the pin slit lengthways and a S-shaped bronze springy-bit fitted to it that works well. |
8th Nov 2014, 4:04 pm | #4 |
I think the VHF socket looks like it will take a standard "VHF" plug with pin dia 1/8 and 3/32, pin spacing 5/16 inch. Both pins 7/16 long. If this is correct I can let you have one for postage.
John. |
8th Nov 2014, 4:14 pm | #5 |
The VHF pug you are looking for looks like this,its non reversable. Can't help with its official description, but someone will know.
Edit..like the one John describes.
Dave G1AGK. My perception is my reality! Last edited by davidw; 8th Nov 2014 at 4:16 pm. Reason: John got in while I was uploading photo. |
8th Nov 2014, 4:18 pm | #6 |
Thank you Dave, that is what I am offering.
John. |
8th Nov 2014, 4:26 pm | #7 |
These plugs had many uses. Used as mains voltage selectors, often mounted directly on a transformer. Similarly used as an impedance selector on output transformers. Often used as speaker sockets as well as FM aerial connectors. Guess it was just easier to use a readily available, low cost part than have something special.
8th Nov 2014, 4:29 pm | #8 |
Yes it is same size as the voltage selectors but this is a plug.
John. |
13th Nov 2014, 12:07 pm | #9 |
Thank you everyone and thank you John for the kind offer. Much appreciated.
