Old 24th May 2006, 8:54 pm   #1
jim_beacon
jim_beacon's Avatar
Default 405 line audio specs.
does anyone know the specification of the audio channel used with 405 line TV? As we have put so much effort into getting pictures on the sets, it would be nice to get the sound right as well.
I'm looking for the audio bandwidth, and whether any compression was used (if so, what were the characterisitcs), and finally, the transmitter mod depth (and was it measured with a stndard line level, peak audio level, or whatever other method the BBC could dream up!).
Thanks
Jim.
jim_beacon is offline
Old 24th May 2006, 10:03 pm   #2
ppppenguin
ppppenguin's Avatar
Default Re: 405 line audio specs.
From memory, the sound carrier was 6dB below peak vision carrier. Bandwidth was at least 15kHz, limited more by the production equipment than any inherent characteristics of the channel. I suspect that compression was minimal in the early days, it was called a sound mixer (the person!) with hands on the faders.
Using the BBC standard PPM scale, I would have expected 6 on the PPM to correspond with 100% modulation.
ppppenguin is offline
Old 24th May 2006, 10:13 pm   #3
Steve_P
Steve_P's Avatar
Sorry Jeff, but 6Mhz is the figure used on UHF.
For VHF, look here: www.penders.cwc.net/otindex.html and click on Standards Info on the left. Should tell you all you need!
Cheers,
Steve P
Steve_P is offline
Old 25th May 2006, 6:58 am   #4
ppppenguin
ppppenguin's Avatar
Steve, where did I say 6MHz? I mentioned 6dB below vision carrier and 6 on a PPM. On system I (as used on UHF in the UK) the sound carrrier is (I think) 20dB below vision.
Old 25th May 2006, 9:22 am   #5
Panrock
Panrock's Avatar
Hi Jeffrey,
From the pre-war 'black book' I seem to remember the ratio was 7dB - but this really is splitting hairs and it could have been changed later anyhow.
Let's say the ratio of peak vision to mean sound carrier was 6dB... Doesn't this then imply that peak sound and peak vision powers were actually identical - or have I missed something?
Steve O
Panrock is offline
Old 25th May 2006, 9:39 am   #6
ppppenguin
ppppenguin's Avatar
AFAIK this 6dB means peak vision voltage to mean sound voltage so I think you are right. Unless they mean 6dB power ratio in which case the voltage ratio is 12dB. In any case that was an awful lot of power to put into the sound transmission. This must have given much greater range to the sound than the vision.
Old 25th May 2006, 4:46 pm   #7
Steve_P
Steve_P's Avatar
Sorry Jeff.
At the moment I am in a lot of pain due to my arm. I hope it works after all this!
By the way, in the 80s the sound carrier on 625 was reduced from -6db of Vision to -10db of vision. There was a massive shutdown at Eyemouth (I was in the team at Selkirk at the time) because it hadn't been adjusted to cope and stayed asleep....
Cheers,
Steve P
Steve_P is offline
Old 25th May 2006, 6:33 pm   #8
jim_beacon
jim_beacon's Avatar
Steve,
your site gives the relative sound level and the sound carrier offset, but not deatils of the bandwidth of the audio channel, whether or not it is compressed, or the mod depth.
Jeffrey,
thanks for your tips, I'm off to read up about PPM's - us comms engineers like our levels pinned down!
Thanks to you both
Jim.
Old 28th May 2006, 12:25 am   #9
Hybrid tellies
Hybrid tellies's Avatar
I seem to remember reading somewhere that the bandwidth of the 405 line AM sound cannel was either 100Khz or possibly 200Khz.
Why so wide? apparently it was to reduce the effects of impulsive noise from car ignition, light switches and thermostats etc which caused real problems on the lower frequency VHF band 1 channels.
Simon
BVWS member
Hybrid tellies is offline
