Old 14th Oct 2015, 9:17 am   #21
Martin G7MRV
Default Re: Farnell Bench Power Supply LT30-2
Just borrowed an LT30-2 from work and need to set constant current. Came online to search for the manual, and lo! The forum has me sorted instantly!
Thanks for the manual!
Martin
I got food in ma belly and a license for ma telly
My Blog - http://g7mrv.blogspot.com
Martin G7MRV is offline
Old 23rd Jan 2016, 12:28 am   #22
high_vacuum_house
high_vacuum_house's Avatar
Smile Re: Farnell Bench Power Supply LT30-2
In an earlier thread I mentioned that I replaced one of the coarse voltage control pots which had gone intermittent with a Bourns 5K 10 turn type and I have now got very good voltage control as it takes 10 turns rather than a single turn to swing between 0-30 volts.
Recently the current limit pot had gone intermittent and the current limit would swing wildly when the knob was touched and so tonight I replaced it as well with a Bourns 10 turn pot. I now have very good current setting resolution and can almost set the current limit to 1-2 mA of a desired value anywhere from 7mA to 2A
When time permits I shall swap the left hand channels pots over from single turn types to 10 turn types.
Christopher Capener
Interests in the collection and restoration of Tefifon players and 405 line television
high_vacuum_house is offline
