Old 28th Mar 2010, 6:51 pm   #21
PJL
Default Re: Polyskop III - any info in English?
I obtained a copy of the english manual for the display unit and it uses standard easy to obtain components. A wash, recap, one o/c wirewound resistor and a few u/s trimmers and it is working OK but will need a little more TLC and re-calibration.
The sweep generator is another matter - it blew the fuse after a few minutes but seemed to do little else. The problem is I have no documentation and a limited number of fuses. It uses similar trimmers which will need replacing, so I am stuck without re-calibration details.
Anybody out there with access to a manual?.
PJL is offline
Old 29th Mar 2010, 9:13 pm   #22
PJL
Caps, caps and more caps. I have removed the supply to the crystal marker which contains most of the leakage and the oscillator and sweep are now working so I just need a bag full of replacement electrolytics.
I will have to work carefully to minimise disturbance as I don't have alignment instructions. Looks like it could be a happy ending after all...
PJL is offline
Old 3rd Apr 2010, 10:49 pm   #23
PJL
Here is a first picture of the working polyskop III. I made a quick resonant circuit with a ferrite cored former and 180pF and put it in series. You should just be able to make out the markers with a double height at 10MHz it makes it about 17MHz.
The bad news is the two differential amplifiers are just that and don't have the detector which I think was part of the probe. I am going to have to play around to see what can be made.
PJL is offline
Old 4th Apr 2010, 10:05 am   #24
PJL
Having thought about it, in many cases an amplifier is all that is needed as I can look post detector. However, I should be able to make a very simple very low capacitance probe using a UHF detector, a capacitor and resistor which should at least work at VHF.
PJL is offline
Old 5th Apr 2010, 8:26 pm   #25
Vectamart
Vectamart's Avatar
Many years ago (early to mid 1970s) I worked at GCHQ in Cheltenham and we used a Polyskop to align the 40 and 37.5 MHz band pass filters in Racal RA17 series communication receivers. This could be a long and frustrating procedure but was made simpler using this instrument which plotted a response curve for both filters on the screen, side by side. This enabled the technician to align for best response and relative amplitude for both filters.
A very large piece of kit which, if I remember correctly, was mounted on a taylor-made trolley and had a 17" CRT.
Vectamart is offline
Old 27th May 2010, 12:52 pm   #26
woodchips
Hello, I too have just aquired a Polyskop 3, came with a collection of other test equipment and looked useful.
Closer inspection revealed that although the sweeper is labelled 0.1 to 1000 MHz, mine only has labels by the range switch from 0.1 to 165 MHz. Looking inside and there is a missing coil pack, so do the higher ranges use overtones?
Powered it up and get a faint trace on the CRT, infact multiple traces since mine has four channels. That is as far as I got, wasn't certain it was worth the effort of repairing given the miserable frequency range.
Has anyone ever modified the 86xxx HP sweeper plug ins for the 8620/8530 sweepers to run on their own? From the manual it looks reasonable easy, few power supplies plus a ramp which should be possible from a decent function generator. I have the 86220 0.1 to 1300 MHz unit, several in fact, but only one 8620 mainframe.
Bob
woodchips is offline
Old 18th Aug 2010, 5:14 pm   #27
Chaparal
Chaparal's Avatar
some SWOB 3 Accessories
Manuals available (pdf)
Peter
Name:	R+S SWOB3-Z - Insertion Unit.jpg
ID:	39542   Click image for larger version
Name:	R+S SWOB3-Z - RF-Probe.jpg
ID:	39543   Click image for larger version
Name:	R+S SWOB3-Z - VSWR Bridge.jpg
Chaparal is offline
Old 1st Oct 2010, 9:53 pm   #28
Alan Ainslie
I wonder - did anyone ever get English manual for SWOB3? Or even German? I need a manual and schematics as I have a troubled PSU here.
Alan
Alan Ainslie is offline
Old 2nd Oct 2010, 8:25 pm   #29
Richard ZS6TF
I bought a Polyskop III today at a flea market and managed to download the German instructions. Like Stelios I would like to get the same in English.
Richard ZS6TF is offline
Old 3rd Oct 2010, 12:07 pm   #30
6AL5W-Martin
Originally Posted by PJL View Post
*** HELP *** anyone know what the value of a M0.63C/250 fuse might be? Is it going to be 0.63Amps?.
0.63 A , 630mA
C , "slowly" ( B = normal, A = fast )
250 Volts.
greetings
Martin
6AL5W-Martin is offline
