25th Mar 2021, 1:13 pm | #81 |
Re: EKCO U122 - Restore or spares?
OK, you have changed the relevant caps.
25th Mar 2021, 1:17 pm | #82 | |
Lawrence. Last edited by ms660; 25th Mar 2021 at 1:36 pm. Reason: missing info |
25th Mar 2021, 1:54 pm | #83 | |
V1 Osc 46.6k V2 2.32M V3 1.24M V4 886k
BVWS Member |
25th Mar 2021, 2:37 pm | #84 |
Whilst waiting for Laurence to reply (I'm also curious as to how to interpret the figures) apply your injector and tracer at volume control and report back your findings
25th Mar 2021, 2:40 pm | #85 |
25th Mar 2021, 3:05 pm | #87 |
25th Mar 2021, 4:08 pm | #88 |
Lawrence - very early on in this Thread you advised me in relation to the Output Transformer connections and that the Primary hadn't been connected for optimum anode load impedance.....9k as opposed to 3k. As a consequence the existing connections were moved to Tags 2 and 3. Any chance that this could be the source of the distortion/instability?
BVWS Member |
25th Mar 2021, 4:38 pm | #89 | |
Lawrence. |
25th Mar 2021, 8:53 pm | #90 |
Not sure if I'm looking in the right place by experimenting with the connections to the Output Transformer Primary but this is what I'm measuring for V4 (UL41) when connected to Tags 2 and 3:-
Pin 2 Anode 210V (Spec 213V) Pin 5 Screen 56V (Spec 76V) Pin 6 Control Grid 0.14V Moving the connections to Tags 1 and 3:- Pin 2 Anode 181V (Spec 213V) Pin 5 Screen 63V (Spec 76V) Pin 6 Control Grid 0.26V Two issues appear to stand out, firstly there is a low voltage reading for the Screen Grid and secondly there is a small, positive voltage on the Control Grid. For the record, moving the connections didn't appear to have any impact on the audio warbling! Simple questions I hope - what is the technical name for the warbling I am hearing and where is the probable source of this distortion? And finally, is this the same as instability??
BVWS Member |
25th Mar 2021, 8:57 pm | #91 |
Can you post a sound/video clip of the symptoms?
Lawrence. |
25th Mar 2021, 9:18 pm | #92 |
Donald, you need to try to narrow down the fault imo. As I mentioned earlier, place your velleman tracer probes on the volume control and check whether the output from the velleman speaker is distorted or not. If it is NOT distorted, this narrows the fault to the AF stage. Confirm this by switching to the injector.
If it is distorted when you place the tracer probes on the volume control, the problem is with the RF/IF stage. Once you know where the fault is, you can focus on investigating the appropriate stage If you think the fault is with the output transformer at least use to AF tracer probe to confirm the sound is clear up to that point. Gabriel |
25th Mar 2021, 9:40 pm | #93 | |
No grid bias would cause the sound to be distorted. Lawrence. |
25th Mar 2021, 9:56 pm | #94 |
Donald, re the small positive voltage on control grid see here.
https://www.vintage-radio.net/forum/...ad.php?t=86050 Also check r20 and r18 they're probably both a bit high. Gabriel |
26th Mar 2021, 10:29 am | #95 |
I double-checked the voltage reading for the Control Grid (Pin 6) of V4 (UL41) and it remains at +0.26V - so clearly problems here with the bias as Lawrence states.
Checking the Control Grid on the other valves I am reading:- V3 (UBC41) -0.30V V2 (UF41) -0.01V V1 (UCH42) -0.20V Looking closely at the circuit and the set, the likely culprit could be C24 the A.F. Coupling capacitor (!) although this is the first cap that I changed? I'll also check R18 and R20 as Gabe suggests and will dig out my Velleman injector and tracer.
BVWS Member |
26th Mar 2021, 11:27 am | #96 |
A new plastic film capacitor is very unlikely to be bad.
Do you have another UL41 to try? |
26th Mar 2021, 11:57 am | #97 |
Just for completeness, in particular as you set has been got at to some extent, can you remeasure the grid bias with reference to cathode rather than to chassis (unless you've done this already). This may give you exactly the same reading but worth a quick check IMO.
The UL41 positive voltage is likely due to internal leakage (deposits), as Paul said your brand new capacitor is unlikely to be leaky. |
26th Mar 2021, 1:35 pm | #98 |
As expected, the new plastic film capacitor isn't the problem (thanks Paul) and is measuring correctly. R18 is also new and not a problem although R20 is another 'bodge' comprising two large 1.5k ohm resistors in series - R20 should be 3.3k ohm. One of these resistors is measuring 1.53k while the other is measuring 2.56k - total resistance across these two (in series) is measuring 4.09k ohms. These resistors wired in series across the Output Transformer are shown on the third picture in Post #1 above. Probably should be replaced?? Voltage across R20 is 61.2V so using our old friend Ohms Law I calculated 0.91W, so using 2W resistors should be ok or would 5W be more suitable at this location?
Found my third and last UL41 valve and fitted that - the warbling has gone and the Control Grid voltage now reads -0.5V - much happiness! Still got a bit of residual background hum but remembered that back in Post #89 Lawrence said "Also be aware that any residual hum level from the output stage might be higher than it would have been with the original type of output transformer fitted, unless some extra HT filtering has been incorporated." The speaker now has a bit of a flabby bass but I'll try and address that by an application of 50/50 Water/PVA to tighten up the speaker cone. My stock of UL41s has now gone so what's the current thinking on alternatives, ideally without changing the valve base? Thanks to everyone for their help and assistance in getting through this but I didn't expect to have two duff UL41 valves!
BVWS Member |
26th Mar 2021, 1:59 pm | #99 | |
To measure g1 voltages use a DMM, preferably one with a 10meg input impedance. Lawrence. Last edited by ms660; 26th Mar 2021 at 2:05 pm. |
26th Mar 2021, 2:44 pm | #100 |
See this writeup for info on replacing the UL41 with a UL84: https://www.vintage-radio.com/recent...bush-ac11.html
That was the 'official' way to replace a UL41 in the 60s as warehouse stocks started to dry up. You can also fit a UCL82 or UCL83 if you have a good one to hand. A Mazda 10P13 can be used as a plug-in UL41 replacement, but they are no easier to find. A UL46 can be used with a base rewire, but again they're pretty thin on the ground. |
