4th Sep 2011, 9:01 am | #21 |
Re: 4 Digit Up/Down Counter IC?
What Jeffrey says is correct, I certainly wouldn't advocate using graphical input to do a large FPGA project. However, for a relatively simple CPLD project like this, I can't foresee any problems from the Altera side.
As an aside, Altera's current S/W (Quartus) is a big, and it's not always apparent where everything is "hidden". I would consider using the older MaxPlus S/W, that is contemporary with the devices I suggest. I've done many simple graphical entry projects with this without the slightest issue, and I've also done some "hybrid" projects that use the graphical input to " bolt together" logic blocks I have constructed myself from VHDL. This approach is not really what VHDL is "all about" (unitary project description) but I found it was a good way to "ease" myself into the "nuts and bolts" of the language (for someone whose brain was wired to creating something from component parts (TTL etc). https://www.altera.com/download/dnl-index.jsp
Chris Last edited by evingar; 4th Sep 2011 at 9:23 am. |
4th Sep 2011, 10:18 am | #22 |
An average CPLD project is often going to be a single VHDL module anyway so all the issues of "wiring" modules together just don't arise.
I was a schematic entry "refusenik" for many years until finally I saw the light and started on VHDL. Unfortunately my entry point was a complex project which made the learning curve very steep indeed. |
4th Sep 2011, 11:17 am | #23 |
Though really a PIC 18F with JAL would be easier if you have any experience of Pascal, Visual Basic, MS-Office Macros or C. Non-volatile
The 18F2550 is very cheap and all the tools (Linux or Windows) are free. It has option for USB (just add socket and a capacitor) and then you could even have PC based position control. Even a 16F is fast enough. But the 18F is about same price and 4.8x faster. There is also Analogue I/O too. A combo counter / level display using small VFD, LCD or LEDs is possible with bargraph and/or digits. CPLD is also a useful skill but not as general purpose. It beats the PIC hands down on a high speed application. (MHz events). The PIC 18F will easily handle general I/O up to 20KHz and more specialised Digital counting/timing to many MHz with onboard HW counters that can be mapped to input pins. JAL http://groups.google.com/group/jallib (JalEdit recomended for Windows, but you can use any editor) http://justanotherlanguage.org/ The device library support (all open source) is amazing on Jal for 10F, 12F, 16F and 18F PIC families. |
4th Sep 2011, 12:19 pm | #24 |
I really must have a go with PICs. They seem incredibly cheap and versatile.
4th Sep 2011, 3:08 pm | #25 |
Go for it - lots of help available on the internet, and personally, I love the assembly language (but then, I'm weird!). The 16F devices are a good place to start, and there's a basic Velleman dev kit for around £20 that we give out to students. Once you get to the 18F devices you're allowed to consider C or some other language, but you'll appreciate the low-level knowledge when doing time-critical stuff.
Some years back I started a basic introduction guide on my site, although I suspect you'll find it rather too basic... |
4th Sep 2011, 11:45 pm | #26 |
I thought I'd posted a reply earlier but it hasn't appeared yet, so I don't quite know what happened to it!
Thanks to everyone for your comments and suggestions, in particular, Jeffery, for kindly taking the trouble to provide a code fragment example for an up/down counter, Mark, and Chris. There's a lot of information to digest, so I guess it will take a little while. At the moment, I'm tending towards using a PIC for this application, if only for the non-volatile memory they contain, unlike, it seems, FPGAs and CPLDs. Even if I do go down that route, I'll still look into using FPGAs and/or CPLDs for possible future use. Many thanks to you all, once again. Regards, Dave. |
5th Sep 2011, 4:31 pm | #27 |
Dave, you should definitely try some PIC programming, I can thoroughly recommend it.
I've made loads of little projects using PIC's, you can get a USB programmer on ebay for £15 which cuts down the programming time etc, you can even use its 5v supply to run your project! I've not tried JAL, instead I program in C, which for 'nuts and bolts' work is dead easy. C can be a bit confusing when you start doing really complicated stuff. For your display you could use some I2C serial devices, you can get a chip which handles figure-8 displays, can't remember the number but there are plenty out there. Give it a go, you won't regret it! Dave. |
5th Sep 2011, 4:39 pm | #28 |
Hello Dave,
Thanks for your comments. I probably will give PIC programming a go. There are so many different programmers and programming languages available, that it's a bit daunting trying to decide what to get! Regards, Dave. |
5th Sep 2011, 7:52 pm | #29 |
To be honest, you probably won't need a separate IC to drive the display; the PIC can do it all. Perhaps you might need to buffer it a bit, as last time I checked, the current limit of each pin was 25mA. There are countless examples of how to drive a multiplexed 7-segment display on the web and in books...
For this, I'd really advise assembly language. OK, there's a bit of a curve at first, but it's be best way to get to understand these devices. Especially for something simple like this. Higher level languages have their place, but I really think that it's best to start at the beginning. Plus, if you're using assembly, I'll be able to help Cheers, Mark |
5th Sep 2011, 9:03 pm | #30 | ||||
Hello Mark,
The main difficulty, as I see it, in choosing a programmer, is that some seem not to have anywhere to 'plug-in' a PIC whereas others do, using SM techniques, DIL or ZIF sockets, sometimes in combination with PLCC to DIL adaptors. I suppose it's mainly because I'm not familiar with them! They also come in a very wide price range, from as little as a few pounds to well over a hundred! Are the cheapest ones going to be not much use and the expensive ones more sophisticated than needed? Just how does one decide! Quote:
Regards, Dave. |
5th Sep 2011, 10:09 pm | #31 |
Hi Dave,
You're right - it is daunting! There is a PIC for everyone, but where to start. For years, the 16F84 was the favorite, and that's what I use for my simple "getting started" guide on my site. But for some time now, Microchip have been trying to persuade people to use other devices, by putting the price up. But, it's a perfectly good chip, and I'm sure I could find a spare one if you like. In terms of the programmer, I built a JDM clone - these are serial port programmers that work pretty well for the money. I mentioned a Velleman kit earlier; here it is: http://cpc.farnell.com/velleman-kit/...0846?Ntt=k8048 Note that any serial programmers need a genuine serial port - a USB to serial dongle won't work. But you don't need a modern machine to do this, indeed it's a good way to get some use from an old P1, P2 or P3 system. The PIC that comes with the Velleman kit is a 16F627. This is largely comparable to the 16F84, but adds a few new facilities like an ADC. My "getting started" guide will apply to this chip, although you'll need to add one or two lines to the "init" subroutine and you might need to use different ports (very easy). I'll look up the details tomorrow when I'm back at work. The Velleman kit doesn't use ZIF sockets, but for basic learning purposes, you can just leave the PIC in the socket, and flick a toggle switch when you want to programme. Flick it back again to see the results. Once you've got past the "hello world" stage, you'll want to use a breadboard or Veroboard or similar, but as there are only three signals plus ground to connect to the PIC while programming, a plug-in wire is easier than removing the IC, or paying for ZIF sockets. I use an old CD-ROM audio cable, which (unusually) has 3 cores inside the screen... There are lots of questions when beginning - there are hundreds of approaches, and I'm not saying mine is the best way, but do have a look at my guide because it is a very gentle introduction. It's not finished, not by a long way, but it should help you make your first tentative steps. http://www.mhennessy.f9.co.uk/pic/index.htm Cheers, Mark |
6th Sep 2011, 12:48 am | #32 | ||||||
Hello Mark,
Talking of prices, I can get the Velleman K8048 from ESR Electronics for about £4.50 less than CPC/Farnell! Quote:
I looked for the MPASM Assembler on the Microchip site, they don't make it easy to find where to d/l it! I searched for it and got 2240 results! I also looked at the IC-Prog site mentioned in your guide but couldn't find anywhere to d/l that either! I clicked on the ConTEXT link in your guide but didn't see anything about that editor! Regards, Dave. Last edited by Amraduk; 6th Sep 2011 at 1:00 am. |
6th Sep 2011, 7:33 am | #33 | |
http://www.contexteditor.org/ |
6th Sep 2011, 9:25 am | #34 |
I would suggest that if you want to start with the Microchip PIC machines, don't waste your time with the old 8-bit ones that everyone talks about (12F to 18F) which are quirky and awkward.
Use the "dsp" versions such as the 24F, 30F and 33F series (all run the same core code). These are proper multi-register 16-bit machines somewhat like older mini-computers. They are seriously easier to code and are much faster both because they will run quite fast clock rates but also that each instruction gets more useful work done. You won't see much price difference (for one-off projects). They are amazing little machines with all kinds of nice I/O features and they still make a few models in old-fashioned DIL packages - right up to 40-pin if you need the pins. All the development software is free from Microchip and their support services are amazing. It's worth buying the cheap in-circuit programmer/debugger which allows you to step through and debug the code on your actual system. |
6th Sep 2011, 9:34 am | #35 |
While I have never used PICs I can concur with George's approach. When the objective is to get the job done, don't skimp on the tools. Whether these are soldering irons or software packages.
I know that I come to this from the professional side - I can usually afford to spend the money on tools to get the job done - the cost of PIC tools and devices is so low that even the better ones are easily affordable for the enthusiast. |
6th Sep 2011, 11:02 am | #36 |
If you do go the PIC / assembler route then it might be worth looking at
http://picprojects.org.uk/projects/counter/counter.htm No encoder interface, but the source code for the counter and led driver is there. I think a software interface to the encoder interface should be fast enough (see http://www.tufts.edu/programs/mma/em...aryEncoder.pdf), however if you are worried there are PICs such as the PIC18F2331 which have the hardware built in (microchip call it QEI) Jim |
6th Sep 2011, 12:11 pm | #37 |
Hello Jeffrey,
Thanks for the link to the ConTEXT Editor, it worked fine. The one in Mark's guide is: www.context.cx/, not the same at all! Regards, Dave. |
6th Sep 2011, 12:23 pm | #38 | ||
You're quite right; I really must update the website. A while back Eden Kirin, the original developer, sold the project to a guy in the UK. The .cx address stayed alive for quite a while after this, but has obviously gone now. Quote:
But folks, this is a 4 digit BCD counter driven by a rotary encoder! There's really no need for anything more advanced, providing the PIC can keep up with the count speed... By all means be aware of the other options for more advanced projects, but as I said in my first post, this is a really good way "in" Mark |
6th Sep 2011, 12:42 pm | #39 | |
Just look under "development tools" on their main page http://www.microchip.com and follow the link for MPLAB IDE. |
6th Sep 2011, 1:43 pm | #40 |
MPASM was always available as a separate download - useful in the dial-up days as MPLAB is quite large, plus early versions were not very good. However, you're right; it appears that Microchip no longer offer it as a separate download.
Dave, worry not; MPASM is part of MPLAB. Another change I need to make to the guide. Still, it was written some 6+ years back, so not surprising, I guess... |
