Old 25th Feb 2017, 4:56 am   #141
roverp6
roverp6's Avatar
Default Re: Tandberg Huldra 8 valve failure
I had the black probe attached to the chassis, where should i have put the black probe?
roverp6 is offline
Old 26th Feb 2017, 12:14 am   #142
PJL
Try measuring the EF89 heater AC voltage with the new meter.
Do the two 'security lamps' show a low resistance? Are you waiting for the replacement fuse?
PJL is offline
Old 26th Feb 2017, 3:21 am   #143
roverp6
roverp6's Avatar
Yes i just ordered some fuses from England, where i live i cant get anything that is close to the right fuse..............very much a backwater. i ordered slow blow 2A 500v 6.2x30mm closest i could find to the original 2000mA 5x30mm
i also have checked the 2 other fuses that look like lamps S5/S6 12v 18w Osram No 6475 they have continuity. will work on the new measurement on the EF89..........."security lamps" are you referring to sikringslampe translated to fuse lamp?
clive
roverp6 is offline
Old 27th Feb 2017, 1:47 am   #144
roverp6
roverp6's Avatar
all the reading from 4 valves are 6.6v on sockets 4 and 5 the only valve i didn't measure was the magic eye. the fuse S1 has blown should i change out capacitors C704 and C705?
Clive
ID:	138254   Click image for larger version
roverp6 is offline
Old 27th Feb 2017, 2:32 am   #145
Boater Sam
Why would you want to? They are most unlikely to be faulty, is this a guess or just something to do?
Boater Sam is online now
Old 27th Feb 2017, 3:30 am   #146
roverp6
roverp6's Avatar
i only mentioned it because i have new replacements and is connected to the blown fuse, and it was a guess.
roverp6 is offline
Old 27th Feb 2017, 9:35 am   #147
'LIVEWIRE?'
'LIVEWIRE?''s Avatar
The fault is more likely to be the rectifier (D701), smoothing capacitors (C11), or in the transistor amplifer, which is powered from the 33vDC supply. Putting an ammeter (on AC Amps range) if your meter has one, across the S1 contacts (without a fuse in place) and measuring the current before and after disconnecting suspect components will indicate which part is the culprit, which is unlikely to be C704 or 705.
'LIVEWIRE?' is offline
Old 27th Feb 2017, 10:01 am   #148
PJL
You might blow the fuse in the meter so I would suggest you use a lamp limiter when you do this. As a fault has already been repaired in the HT PSU, I am hoping it is just the fuse that has gone.
PJL is offline
Old 7th Mar 2017, 5:01 pm   #149
roverp6
roverp6's Avatar
taking a time out until i get the fuses, giving the experts here a break
roverp6 is offline
