Old 6th Jan 2017, 10:15 pm   #81
roverp6
roverp6's Avatar
Default Re: Tandberg Huldra 8 valve failure
here is the volt reading across the fuse holder T1160mA250V. this powered up running through the dim bulb tester 60w bulb
roverp6 is offline
Old 6th Jan 2017, 10:52 pm   #82
That's good. All you need now are some 160mA fuses.
Station X is online now
Old 7th Jan 2017, 1:07 am   #83
roverp6
roverp6's Avatar
Thanks Graham will report back when the supplies come in and to all who helped so far
roverp6 is offline
Old 11th Jan 2017, 9:12 pm   #84
roverp6
roverp6's Avatar
i need to order some capacitors from Just Radios here are the original values: replacements in bold
0.01 uF 1000V (Rifa brand)
replacement 0.01uF 1000V Tubular Axial Metalized Polyester/Polypropylene Film Capacitor
0.022 uF 400V (Rifa brand)
.022 uF at 400 V 2G 223J Mylar Polyester Film "Green Dips" ( 400V)
32 uf 350v (Electrolyte PEG 1081 E/74 Rifa)
33 uF at 350V axial E-caps @ 350 Volts
are my choices right?
noticed he has capacitor kits is this a good option?
if i cant find 400V capacitors in the specification can one go up to 630V? in the correct uF value.
Clive
roverp6 is offline
Old 11th Jan 2017, 10:15 pm   #85
The caps you've chosen will be fine.
There is no harm in using caps of a higher voltage rating than the originals.
Old 11th Jan 2017, 11:02 pm   #86
roverp6
roverp6's Avatar
Thanks Graham
roverp6 is offline
Old 18th Feb 2017, 3:14 am   #87
roverp6
roverp6's Avatar
Brief Update: put the new fuse in and capacitor plug in to the dim bulb tester.
no flashes,smoke. the magic eye did move with signal strength on FM, that's the only band i used...........first noticeable observation no audio nothing even moving from record player and back to radio. one valve i noticed doesn't appear to light up all the other 4 do it is identified as EF89 see section of diagram were it is located, is it in he amplifier section? and how do you check for continuity? which pins.
Thanks
Clive
roverp6 is offline
Old 18th Feb 2017, 3:27 am   #88
G8UWM-MildMartin
Pins 4 and 5, as shown on your diagram.
G8UWM-MildMartin is offline
Old 18th Feb 2017, 9:17 am   #89
Freya
Freya's Avatar
The EF89 is used as a Radio Frequency amplifier. It could explain the blown fuse if it had an internal structure short.
Stephen
Freya is offline
Old 18th Feb 2017, 11:08 am   #90
Hunts smoothing bomb
Hunts smoothing bomb's Avatar
Yes, correct, the output of this valve feeds the FM discriminator and then on to audio amplification and output. If this valve is not lit then there will certainly be no audio.
As the magic eye is responding this is a good indication that the radio is receiving signals.
We are close now. Get a replacement EF89.
Lee
Old 18th Feb 2017, 11:24 am   #91
I'm confused as to why the magic eye would work when tuning FM if the EF89 was duff?
Old 18th Feb 2017, 11:31 am   #92
Am I right in thinking that the EM87 gets its signal from the EAF801 output via D201 which is before the EF89 demodulation stage?
Lee
Old 18th Feb 2017, 11:35 am   #93
Yes, so far as I can make out on AM, on FM it appears to be via R220 and R221.
Old 18th Feb 2017, 11:37 am   #94
Ah hold on, looking at the circuit it would seem that I have described how the EM87 gets its signal on AM!
It looks indeed as though the EM87 gets its signal from the output of the discriminator on FM so yes, I cannot see how it is working with a dead EF89.
Lee
Old 18th Feb 2017, 6:23 pm   #95
roverp6
roverp6's Avatar
ordering a replacement EF89 will be my next step, then we shall see how we progress, excellent support as usual.
Clive
roverp6 is offline
Old 19th Feb 2017, 2:32 am   #96
roverp6
roverp6's Avatar
here are some pics of readings taken from the valve base pins 2 and 3 of EF89, and the magic eye tuned to a FM station.
Clive
ID:	137843   Click image for larger version
ID:	137844   Click image for larger version
ID:	137845   Click image for larger version
roverp6 is offline
Old 19th Feb 2017, 2:42 am   #97
You're numbering the valve pins the wrong way.
Old 19th Feb 2017, 3:09 am   #98
roverp6
roverp6's Avatar
Graham so the pins i listed should be 9,8,7 corrected picture
roverp6 is offline
Old 19th Feb 2017, 6:22 am   #99
julie_m
Yes, exactly. Valve pins are numbered in the same fashion as IC pins; increasing anticlockwise from the break, as you look down into the valveholder. (This sounds a bit wrong, because valves were around before ICs, but you know what I mean; semiconductor manufacturers just adapted the existing numbering scheme for valve pins.) However, valves are conventionally viewed from underneath the chassis; so on this side, the pins numbers increase clockwise from the break.
julie_m is offline
Old 19th Feb 2017, 8:07 am   #100
I thought that the EF89 wasn't lighting up? That being the case you need to check the voltage BETWEEN pins 4 and 5 of the valveholder and the resistance between pins 4 and 5 of the valve.
