11th Mar 2017, 6:52 pm | #1 |
Resco GDM-8 Grid Dip Oscillator
I recently obtained one of these on eBay. It's Japanese made with 6AM4 valve I think, very solid construction and complete with set of plug-in coils. Cannot find any info or handbook on the web at all, anybody ever had one??
11th Mar 2017, 9:56 pm | #2 |
Re: Resco GDM-8 Grid Dip Oscillator
Resco is not a brand that I have heard of previously, but sometimes products were sold in different countries under different names. I keep notes on just about every GDO I ever encounter.
What we need....is a picture . B
12th Mar 2017, 12:01 pm | #3 |
Hi Bazz,
Thanks a lot for the quick reply - you're just what I need, a GDO-collector! Here's the picture, second time lucky, my last reply vanished before <I could complete it! Actually, this unit is very sturdily made with a heavy metal case. I think it works but the deflection I got on testing a MW Rx was very faint, compared to my other GDO which is a Grundig transistor TR 300. Many thanks for your help - what would be very useful at this point is a manual. Best wishes, Chris (HB9HFB) |
12th Mar 2017, 12:06 pm | #4 |
A neat looking instrument. If no information turns up, at least the circuit should not be difficult to trace out.
Usually valve-based dip meters give clearer indications than transistor ones do, so you may have a fault in this one. David
12th Mar 2017, 4:13 pm | #5 |
I have one of these but it's labelled Kyoritsu. I bought it new around 1968. Had some problems with the mains transformer but managed to rework it and it functions as it did. I don't recall the dip being very pronounced though.
I found the circuit on the net and have attached it here. Ian |
12th Mar 2017, 4:14 pm | #6 |
Forgot to say the valve is a 6AF4A.
12th Mar 2017, 5:48 pm | #7 |
Dear Ian and Bazz,
Thanks a lot for the feedback and Ian, for the schematic. Looks like it might be worth replacing a couple of caps and checking the valve on my trusty Hickok 600, which is made for testing American tubes! |
12th Mar 2017, 7:01 pm | #8 |
Interesting to see that is uses three 1pF 'gimmick' capacitors - just a couple of turns of insulated wire taken to ground. Value not critical.
I guess that the use of the archaic term 'uuF' rather than 'pF' dates it to maybe the 1950s or even a bit earlier? Looks a nice piece of kit and luckily, with it's coils intact too.
12th Mar 2017, 7:07 pm | #9 |
Maybe 1,000pF feedthroughs?
Lawrence. |
12th Mar 2017, 7:36 pm | #10 |
Ah Yes - I read1.000 uuf as 1pF but I guess it was 1,000 uuF, so you may well be right Lawrence.
12th Mar 2017, 10:09 pm | #11 |
And if we look at the very recent Post#33 in this thread http://www.vintage-radio.net/forum/s...=134225&page=2 we find the same GDO was sold under the brand "Honor"; apparently very popular in Australasia.
The circuits of valve GDO's rarely deviate from a pretty standard design, so if some work better than others you'd have to think it was in the way they were was constructed. I must get round to building a valve GDO.... or should I do the tunnel diode one first, as per Heathkit (it works on just 1.5V and yes, I have a suitable tunnel diode...I think) ? B
13th Mar 2017, 12:52 am | #12 |
I suspect Kyoritsu will have been the original manufacturer. Many of their products appeared under different names including Eagle International.
Bazz: If you are considering a valve based GDO this looks like an interesting alternative approach. Post #17 on this thread. https://www.vintage-radio.net/forum/...d.php?t=107489 Al
I won't tell you how I discovered that. |
13th Mar 2017, 1:52 am | #13 |
Well, the bad thing about that thread is that I was clearly talking about building a valve GDO back in 2014..and it's still all talk .
The EM valve is interesting, but I'd like to make a valve GDO which could be run on batteries so it is portable, and there's an Acorn valve with a 1.5V filament which fits that bill perfectly . The American "Megacycle Meter", built in the late 1940's and claimed by some to be an exceptionally good GDO, also used an Acorn valve. I loved stuff made by Eagle! B
