14th Jul 2020, 11:36 pm | #1 |
Help identify this radio -
Hi all,
I seem to have fallen at the first hurdle on this project, as I can't identify it! Is anyone familiar with this manufacturer or set? It appears to have no marking inside however what I believe to be G P is shown in the logo at the centre of the scale plate. Any information on this set would be appreciated. Thanks in advance, Garry |
15th Jul 2020, 8:33 am | #2 |
Re: Help identify this radio -
A view of the rear of the chassis and a list of the valve numbers might help. If you have to remove valves to read the numbers be gentle in pulling them out - pull from the base, not the glass if possible. Do them one at a time so that you replace them into the correct socket. Cheers, Jerry
15th Jul 2020, 11:13 am | #3 |
Welcome to the forum! I have just looked through Pauls excellent database DVD and not a thing under GP, GE yes. Of course if it is all there, it should be an easy fix.
15th Jul 2020, 11:35 am | #4 |
Looks like mid 30's British judging by the station names.
Time flies like an arrow, fruit flies like a banana |
15th Jul 2020, 11:43 am | #5 |
Yet the cabinet is very 1950s.
Maybe a “bitsa”? |
15th Jul 2020, 11:59 am | #6 |
Department store special? Couldn't find anything in RM from 1933-38.
15th Jul 2020, 12:02 pm | #7 | ||
Yes, I had come to the same conclusion, I just took a slightly better photo which shows all stations a bit more clearly Quite possibly! Thanks all for your comments so far! |
15th Jul 2020, 2:00 pm | #8 |
According to Set makers page 173
The tobacco company Godfrey Phillips Ltd commissioned KB to make 40,000 two valve 'Masterpiece' radios for them which they gave away when you'd smoked 500 packs of ten (assuming you lived that long). It's not this model but the GP could be Godfrey Phillips, perhaps getting their own cabinets made for commissioned chassis? John |
15th Jul 2020, 2:10 pm | #9 | |
15th Jul 2020, 2:15 pm | #10 |
I just wonder if it is a George Palmer set He used the names Muzzulphone, Ardiphone and Palmerphone, or George Potter was City These sets were from the 1920s. Did they produce sets later on in their lives?
John.
My favourite text message "I'll be there in five minutes, if not read again" |
15th Jul 2020, 2:36 pm | #11 |
It looks to have octal valves - which would place it sometime very-late-1930s onwards.
The 'blank space' on the scale-plate would probably have been for a 'magic eye' tuning indicator. Under-chassis it looks to have several replacement parts - the volume-control pot looks suspiciously clean and there are a few plastic-cased capacitors that look like 1960s Radiospares parts. Would be interesting to loosen the clip on the big smoothing-electrolytic and ease it up a bit to see if there's any date printed on it. I don't see an output-transformer or an HT smoothing-choke, but I do see what looks like two output-valves, and the metal-can valve behind the red-painted EBC33 could be a phase-splitter. Push-pull output-transformer mounted on the [energized] loudspeaker probably. Is that a small 4-pin or 5-pin paxolin socket I can see lurking behind one of the output-valves? That would be for speaker connection. If I had to guess, I'd say it was possibly a just-pre-WWII-or-slightly-afterwards 'bitsa' made by a very small manufacturer - there were loads of these operations around, most had gone bust by the early-50s. Last edited by G6Tanuki; 15th Jul 2020 at 2:46 pm. |
15th Jul 2020, 2:57 pm | #12 |
That chassis looks like a Barker '88' to me.
Andy
G-QRP #12697 |
15th Jul 2020, 3:13 pm | #13 |
Ditto....pre-war Barker 88 chassis.
Lawrence. |
15th Jul 2020, 3:52 pm | #14 |
One perculiarity it appears to have is that there appears to be only one "proper" I.F. transformer. There is an odd what looks like a 2 terminal inductance under the chassis near the I.F. amplifier valve which may be the anode load for that valve, but its hard to see where it actually connects to. The valve holders are unfamiliar to me, too.
I would date it just pre or post war by the component mix. Tony. |
15th Jul 2020, 4:04 pm | #15 |
15th Jul 2020, 4:15 pm | #16 |
Does that look like a metal octal valve just near the centre of the chassis?
Certainly very late thirties, possibly just post-war. The lack of output transformer and likely energised speaker would suggest pre-war. The tuning scale is very professionally printed. Push-pull outputs makes it a little grand even if the RF/IF section is rudimentary. There are brackets and a hole for a magic eye and its socket, so the chassis is intended to go into sets of different levels of poshness. The electronic design may be a bit basic in the RF/IF section but the standard of construction isn't as crude as many low turnover specials were. Interesting set. David
15th Jul 2020, 4:22 pm | #17 |
From this very forum Barker (88) info.
See the comment by Chas at the end of the first paragraph. https://www.vintage-radio.com/manufa...ts/barker.html
15th Jul 2020, 5:53 pm | #18 |
There ws a department store in Marylebone called Gayler and Pope, now defunct. Could the radio have been built for them to sell as an own-brand item?
Gus. Last edited by westcliff; 15th Jul 2020 at 5:55 pm. Reason: typo |
15th Jul 2020, 6:56 pm | #19 |
The red valve with the top cap connection looks like an EF37A to me.
I gather that valve was introduced in 1942
15th Jul 2020, 7:08 pm | #20 |
I saw it as an EBC33: which would make sense as a double-diode detector (demodulator/AGC) and first-audio stage to feed a triode phase-splitter ahead of a push-pull output.
