Old 12th Jul 2020, 3:18 pm   #1
pentoad
Default Testing a Wearite tape deck question
This deck has a hold down solenoid (330 ohms) which energised from the HT circuit of the amplifier (between the speaker primary and previous gain stage)
I do not have the record replay amplifier.
I don't know what power it requires to actuate it.
In order to test the deck I have an adjustable HT power supply source which is okay for 250vdc, how do I go about simulating the impedance load of the el84 output stage so the current draw is correct for the solenoid?
Or do I apply a low voltage and then adjust it until it is sufficiently magnetised?
I don't want to burn the solenoid out as they are unavailable
pentoad is offline
Old 12th Jul 2020, 8:02 pm   #2
ms660
ms660's Avatar
Default Re: Testing a Wearite tape deck question
That seems to tally up with the solenoid in the Ferrograph Series 4 deck, that has a nominal voltage drop of 14 volts.
On playback...HT in = 278 volts, HT out = 263 volts (15 volts drop)
On record...HT in = 240 volts, HT out = 223 volts (13 volts drop)
You can do the Ohms law from that for a series resistance for whatever supply voltage you decide to use.
https://www.vintageshifi.com/reperto...Ferrograph.php
Lawrence.
ms660 is offline
Old 14th Jul 2020, 2:54 pm   #3
pentoad
Thank you for your help
pentoad is offline
