Old 13th Jul 2020, 6:10 pm   #21
G6ONEDave
G6ONEDave's Avatar
Default Re: Help restoring Telefunken Rhythmus Hifi
Still looks like an elec cap to me. If it is a coil it's rather unusual in it's mounting. Would expect a squarish paxolin end and a couple of fixing screws for a coil fitting. If you check the wiring to the ht supply, I would suspect that this item connects to it with a resistor or choke across the 2 terminals of this device. It might be that the can is isolated and one of the 2 terminals is the earthy or negative end of it. Looks a bit too large for any other area in the circuit, unless I am wrong and it is a coil.
G6ONEDave is offline
Old 13th Jul 2020, 11:40 pm   #22
nickfox
nickfox's Avatar
Hi Dave, you're right, it is a cap. I unsoldered one of the legs and measured 30 uF. It looks like there is a 2W resistor measuring 1844 ohms across it.
n
nickfox is offline
Old 14th Jul 2020, 12:26 am   #23
nickfox
nickfox's Avatar
This seems to be the sales brochure for my model.
https://www.***********/photos/29533980@N05/8256848374
n
nickfox is offline
Old 14th Jul 2020, 9:07 am   #24
Station X
Station X's Avatar
n
That suggests there are two capacitors in the can, possibly a reservoir and a smoother, with the can itself being the common negative terminal. Or is there a short across the tags?
Graham. Forum Moderator
Station X is online now
