Old 13th Jul 2020, 5:04 pm   #101
PJL
Default Re: EKCO AD75 restore
You must use the isolation transformer if you are attaching any test equipment as the test equipment will be earthed (or should be!) and you would be shorting mains earth to neutral.
PJL is offline
Old 14th Jul 2020, 10:45 am   #102
thejazzageuk
I've taken the traces. The two attached are V1 anode (pin 5). Just 50hz hum I guess?
When I attach the probe to V2 pin 8, the crackling stops and the speaker is silent and the scope finds no ascillating freq.
ID:	210957   Click image for larger version
thejazzageuk is offline
Old 14th Jul 2020, 8:40 pm   #103
PJL
What type of probe are you using?
The V1 pin 5 trace is very strange as that is a huge amount of hum from somewhere. I guess it could be heater/cathode leakage in V1.
What do V1 pin 4 cathode and pin 8 hexode anode look like on the scope?
PJL is offline
Old 16th Jul 2020, 9:55 am   #104
thejazzageuk
Thanks PJL. I'm using the 10X probe. Should I be attaching the probe gnd to chassis gnd? When I do this the radio outputs a faint 50hz audible hum.
It seems like something has changed in the radio in the last few days. The output volume is lower and I don't hear the frequencies that I previously heard when tuning through the dial.
I think V3 is damaged as the glass was rotating around 10 degrees on the base and will presumabley have damaged some contacts (it's glued now but the damage may have been done). Also V1 was becoming a bit loose as its a tight fit and I've pulled it in and out a few times.
All the traces seem to show only 50Hz. The only exception is on Pin 8 V1 when there appears to be a trace of 2 freqs -50hz and 1250khz (see pic).
Old 17th Jul 2020, 3:28 pm   #105
smiler411
smiler411's Avatar
If you are getting 50hz at every test point I think you have a grounding problem you must connect the probe ground to the radio chassis are you sure you are using an isolation transformer that has no common earth connection hum when you connect the probe ground sounds like a grounding issue
smiler411 is offline
Old 17th Jul 2020, 8:24 pm   #106
PJL
Loose valves are common but rarely mean they do not work.
Can you show us a picture of the isolating transformer and how you have it wired.
PJL is offline
Old 18th Jul 2020, 2:06 pm   #107
thejazzageuk
Here is a photo of the isolation transformer. The 2 wires on the right are the radio power lead.
Old 18th Jul 2020, 7:45 pm   #108
PJL
Looks OK.
Connect aerial earth to chassis and probe earth to chassis and try again.
PJL is offline
Old 20th Jul 2020, 3:34 pm   #109
thejazzageuk
Thanks pjl. I connected aerial and probe earth to chassis ground and did a trace from V1 pin 5 (anode). Unfortunately shows much the same, see photo.
Old 20th Jul 2020, 11:51 pm   #110
PJL
And what about V1 cathode, pin 4, what does the scope image look like? Also check the value of R5 (100K) that should connect from pin 4 to pin 6.
PJL is offline
Old 21st Jul 2020, 9:55 am   #111
thejazzageuk
R5 reads 221k in circuit. When powered there is 125mV AC across it mV DC). Pin 4 also just has 50Hz, see photo. 5
Old 21st Jul 2020, 2:18 pm   #112
PJL
That's a serious amount of 50Hz on the cathode. There are three possibilities:
1. Your scope is not working correctly. Try connecting both the earth clip and probe to chassis.
2. The valve has a heater cathode short. Take the valve out and measure the resistance between pin 4 and pin 2 (or pin 3) on the valve.
3. There is a short somewhere in the wiring between pin 4 and pin 2/3. Either pin 2 or pin 3 is already wired to chassis so it would have to be the other pin. With V1 and V2 removed measure the resistance on V1 socket from pin 4 to the suspect pin (2 or 3).
PJL is offline
Old 21st Jul 2020, 3:39 pm   #113
PJL
The other possibility is the 50Hz is being injected into the triode grid. You can test for this by connecting your scope to V1 pin 4 cathode and shorting pin 5 triode grid to chassis.
PJL is offline
Old 22nd Jul 2020, 9:48 am   #114
thejazzageuk
Thank you PJL. Here are the results of the checks. Hopefully we are gettin closer to the issue now.
1. Your scope is not working correctly. Try connecting both the earth clip and probe to chassis. R: Scope seems OK. Gives a flat line with earth and probe to chassis.
2. The valve has a heater cathode short. Take the valve out and measure the resistance between pin 4 and pin 2 (or pin 3) on the valve. R: Valve seems OK. 6.2R between 2 and 3, O/C for pins 2 to 4 and 3 to 4.
3. There is a short somewhere in the wiring between pin 4 and pin 2/3. Either pin 2 or pin 3 is already wired to chassis so it would have to be the other pin. With V1 and V2 removed measure the resistance on V1 socket from pin 4 to the suspect pin (2 or 3). R: As far as I can tell neither pin 2 or Pin 3 is connected to chasses. Both give O/C to chassis when measured. Pin 1 and 2 are connected togerher on the socket. With the valves removed I measure O/C between 3 and 4, but 195R between 2 and 4.
The 50Hz is being injected into the triode grid. You can test for this by connecting your scope to V1 pin 4 cathode and shorting pin 5 triode grid to chassis. R Both traces seem similar whether Pin 5 shorted to chassis or not. (see pics showing 1. Shorted 2. Not shorted)
Old 22nd Jul 2020, 9:51 am   #115
thejazzageuk
Here are the pics.
ID:	211512   Click image for larger version
Old 22nd Jul 2020, 10:36 am   #116
PJL
The scope is showing a minimum of -4.8V on the cathode and that should be impossible. Is it set for AC coupling?
According to the Trader V1 pin 2 or pin 3 should be connected to chassis. The valve heaters may be wired in a different order, can you please check the wiring.
Another possibility is that the hexode is causing the 50Hz on the cathode. Put your scope on V1 pin 4 again and short V1 top cap to chassis.
PJL is offline
Old 23rd Jul 2020, 11:12 am   #117
thejazzageuk
I think you have hit on one of the faults. When I traced the heater circuit it became clear that the V1 pin 2 goes to a ground point but the bolt on the ground point was loose. I've tightened it up and now the radio sounds much better. Lots of high freq whistles and hums as you tune rather than just a loud buzz. Still will not find a station though and scope traces give unstable waveforms with freqs rapidly changing. Here are 3 traces (taken using ac coupling).
Pic 1. V2 pin 8 anode
Pic2. V1 pin 5 triode anode
Pic 3 V1 pin 4 cathode
ID:	211596   Click image for larger version
ID:	211597   Click image for larger version
Old 23rd Jul 2020, 9:05 pm   #118
PJL
Oscillator is not running.
Have you cleaned the waveband switch carefully?
Measure the voltages on V1 again as they may have changed - pins 4, 5, 6 ,7 8 and topcap.
Check the resistance of the oscillator coils L4, L5, L6 and L7.
PJL is offline
Old 24th Jul 2020, 7:39 pm   #119
smiler411
smiler411's Avatar
isn't waveform 2 the oscillator running, if that is the anode of the triode
Old 24th Jul 2020, 9:19 pm   #120
PJL
819Hz so about 1000 times less than what we are looking for. I guess it is possible that a capacitor has been wired incorrectly.
There is also quite a bit of 454KHz on the hexode anode - not sure if this is instability.
PJL is offline
