Old 16th Oct 2017, 9:54 am   #1
Electricdreams
Electricdreams's Avatar
Default HDMI to 405
Has anyone managed to convert hdmi signals to 405?
Would be good to have a amazon firestick connected to a 405 tv
What have you bought now??
Electricdreams is offline
Old 16th Oct 2017, 10:04 am   #2
peter_scott
peter_scott's Avatar
Default Re: HDMI to 405
If you can make the connection between your Firestick and VLC Player then you are home and dry.
See: http://www.nostalgiatech.co.uk/Baird%20240%20lines.htm
Peter
peter_scott is offline
Old 16th Oct 2017, 9:48 pm   #3
winston_1
The easiest way is an HDMI to composite converter into an Auora.
https://www.amazon.co.uk/s/ref=nb_sb...d=369UWTTUL73U
winston_1 is offline
Old 17th Oct 2017, 2:53 pm   #4
Voxophone
Voxophone's Avatar
I've used something like this and it does allow you to get an image on the screen. However, depending on the source material, you may find you have an aspect ratio problem or black bars at the sides of the picture.
Liam
Voxophone is offline
Old 18th Oct 2017, 8:20 pm   #5
Panrock
Panrock's Avatar
Where it says it converts to 480i, doesn't this mean in effect 525-lines, so it's unsuitable for use with a standard Aurora?
Steve
Panrock is offline
Old 19th Oct 2017, 7:52 am   #6
wd40addict
wd40addict's Avatar
The full description says it also supports 576i. I have a similar unit from esynic which works fine.
See https://www.vintage-radio.net/forum/...d.php?t=110721
wd40addict is offline
