3rd Aug 2018, 12:43 am | #1 |
Tiny adaptor
My friend gave me a tiny adaptor its a 3 way job rated at just 2 amps ive not seen one in years so was very pleased when he gave it to me. A couple of odd things about it is that on one side live and neutral are reversed I think ive read on here of the 5 amp ones having one socket reversed but cant remember what post that was in. Secondly its live pin appears to be damaged in that around half its length there is only half the pin there does anyone know if this was a deliberate feature? Looking at the neutral and earth pins they are a solid peice of metal it doesn't look like its made in two halves so the live pins,a bit of a mystery. Incidentally it fits the socket ok and works well I think it is made by MK as its similar in style to a 5/15 amp MK one I have except its tiny and is white not brown
3rd Aug 2018, 9:39 am | #2 |
Re: Tiny adaptor
This one is Clang, not MK.
http://wiki.diyfaq.org.uk/index.php/...angadapter.jpg They can be right bggrs to reassemble if you take them apart. The short live pin sounds like it's not fixed into the case moulding properly. |
3rd Aug 2018, 10:04 am | #3 |
Re: Tiny adaptor
Possibly somewhere in this closed thread:
https://www.vintage-radio.net/forum/...t=71262&page=7 post #132 in one example. |
3rd Aug 2018, 11:53 am | #4 |
Re: Tiny adaptor
Oscar foxtrot that looks like mine so that means mines probably clang which is means my 5/15 amp ones mite also be clang il take one out and check again.thanks for putting the link in for that foto
3rd Aug 2018, 12:10 pm | #5 |
Re: Tiny adaptor
I think the reversed polarity on one of the side sockets was a matter of taking the easy way out in having conductors that ran in a straight line between the two side sockets, whereas a crossover would have been required to achieve the same polarity on each.
I don't recall split pins on any that I have had, but I'll dig some out after lunch to check.
3rd Aug 2018, 12:24 pm | #6 |
Re: Tiny adaptor
Before the universal 13A system, 2A was one of the hierarchy of old sizes, commonly used for lamps etc. It sounds like it has lost a pin at some time, and replaced with a split type. As it's 3 pin, there would be no need for polarisation or any other form of discrimination.
3rd Aug 2018, 2:09 pm | #7 |
Re: Tiny adaptor
I can't lay my hand on the box of 2A adaptors at the moment, but looking through the 5A ones, all but one have solid pins. The one pictured below, however, has split pins.
By the way, this one does the polarity correctly, but I don't intend taking it apart to show the crossover wiring inside.
Mending is better than Ending (cf Brave New World by Aldous Huxley) Last edited by Dave Moll; 3rd Aug 2018 at 2:17 pm. Reason: By the way... |
3rd Aug 2018, 2:56 pm | #8 |
Re: Tiny adaptor
Sometimes these 2 amp sockets were on the same circuit as the fixed lights, for cheapness.
In better specified homes a dedicated circuit for lighting sockets was provided, this had the merit of providing a bit of redundancy in case of a fuse blowing. Sometimes a wall switch was provided to control the lighting sockets from beside the entrance door, much more convenient than walking round to each socket. Most appliances fitted with these plugs had a very low loading and even a 3 way adaptor was most unlikely to overload a 2 amp socket. Apart from table lamps and floor standing lamps, the most common uses were probably radio sets, Christmas lights, and desk fans. |
3rd Aug 2018, 8:15 pm | #9 |
Re: Tiny adaptor
My adaptor doesn't have split pins let me try to explain it better the earth and neutral are solid pins probably brass the live one hashalf the pin diameter on its lower half so half looks normal the other half is only partly there in effect it only half the diameter I wish could put a foto but any way hope this explanation helps. I remember a relative of mine had a 1960s built house in Rustington near Worthing and that had those little 2 amp sockets installed for table lamps also oddly there was one of them in the boiler cupboard in the bathroom. I also remember a 5 amp socket for an extractor fan in the kitchen the rest were ordinary 13 amp sockets.
4th Aug 2018, 8:50 am | #10 | |
Re: Tiny adaptor
4th Aug 2018, 9:17 am | #11 |
Re: Tiny adaptor
Yes adaptors [or is it adapter?] or rather my childhood version of LEGO.
You think you have seen them all then up pops a version you have never come across before. This range of 2 and 3 pin 2amp types were very common back in the early days of my house service calls. By the end of the 1960's they were vanishing from the skirting boards as the 1930's houses were being rewired with ring mains. As Broadgage mentioned, in the better quality houses the 2 amp sockets were retained on the lighting circuit. GRELCO managed to produce some bizarre examples of excellent quality, all perfectly safe if used as intended. John. PS Any chance of a pic Hans? |
4th Aug 2018, 9:20 am | #12 |
Re: Tiny adaptor
I remember those adaptors: the ones I recall used a large diameter tubular 'nut' with 2 screwdriver-notches, screwed over the transverse earth-socket, to hold the 2 halves together.
2-amp 3-pin sockets were until recently still widely used in places like hotels for bedside-table lights, controlled by the room's lighting switches/dimmers. These days we have remotely-controllable-from-your-phone "smart" light-bulbs/dimmers and sockets instead. |
4th Aug 2018, 11:09 am | #13 |
Re: Tiny adaptor
I see now where the confusion has arisen. I (and presumably others) assumed that the lower half of the pin was of semicircular profile, like a split pin with one half missing, but what you're saying is that the thinner portion has a circular profile of half the diameter. This sounds very odd, so it's a shame you don't have the facilities for posting a picture.
4th Aug 2018, 11:32 am | #14 |
Re: Tiny adaptor
Heatercathodeshort.
Most of the adapters you have in your picture are like the ones in my collection. My mate often brings me a few when he visits, I think he spends a lot of time on eBay! I have also one odd socket, it has smaller pin sizes than a 5 amp also shorter spacing between pins, it seems to be a halfway between 2 and 5 amp most odd. Dave Moll. Yes you've got it. I think it has been damaged at some point in its life although there's no other sign of ill treatment, as I said it works well. I've not put much load on it just a radio cassette player. The socket on my plug board is rather reluctant to accept the new plugs I bought but the adaptor fitted perfectly and the new plugs fit into it easily as well, so good all round really. |
4th Aug 2018, 12:12 pm | #15 |
Administrator
Re: Tiny adaptor
My flat, built in 2001, has three 5A 3 pin sockets in the lounge operated by one of the switches on the wall light switch. It's a nice feature but not the sort of thing that would be on my property buying priority list.
4th Aug 2018, 12:31 pm | #16 |
Re: Tiny adaptor
I recall seeing a wall mounted twin socket labelled 'Aerial + Earth' so clearly meant for use with a radio. I think the spacing was closer than a 2 amp power socket and small pins required - possibly the same a wander plugs 3mm. It was brown and fitted in a house built about the 1920's/30's.
4th Aug 2018, 12:39 pm | #17 | |
Re: Tiny adaptor
David Last edited by factory; 4th Aug 2018 at 12:47 pm. |
4th Aug 2018, 4:08 pm | #18 |
Re: Tiny adaptor
Extension speaker sockets are another possibility. J.
4th Aug 2018, 8:53 pm | #19 |
Re: Tiny adaptor
Hi Gents, lots of these 2/3A 3pin sockets were fitted on new builds in the 60's/70's.
I believe it was for cheapness as no wiring was required up to the ceilings, all under the floorboards. Ed |
4th Aug 2018, 9:01 pm | #20 | |
Re: Tiny adaptor
Quite a good idea as it means plumbers don't have to be trusted to do anything involving fixed wiring. |
