Old 15th Apr 2018, 6:20 pm   #1
mole42uk
mole42uk's Avatar
Default GPO Indicator Gas No5
I recently bought a GPO Indicator Gas No5 in an auction. The instrument is clean and cased but no further information is known. The meter scale reads "Percent Explosive" at the top. I was told it is for sampling the atmosphere in underground spaces before venturing in with tools.
Has anyone any information about these devices?
Richard
Index:
mole42uk is offline
Old 15th Apr 2018, 8:37 pm   #2
Dave Moll
Dave Moll's Avatar
Default Re: GPO Indicator Gas No5
If you're a member of the Telecommunications Hertitage Group, there are lots of documents about this on their resources web site.
Dave Moll is online now
Old 15th Apr 2018, 10:03 pm   #3
philthespark
Ah, so you've got an IG5 then! We used them a lot when I was at BT, (http://www.jmwlimited.co.uk/IG5_Indi..._Detector.html)
They are pretty robust,they had to be, the quickest way to kill one was to suck water into it, they have a filter that goes in the sampling line to prevent debris and water being sucked into the sensor, they are a handy tool for checking for flammable gas in chambers and cabinets, although iirc they are designed for natural gas and don't like petrol fumes.
Somewhere I have my original BT training manual and I'm sure it has the operating manual in it, I'll dig it out and copy it for you.
philthespark is offline
Old 16th Apr 2018, 7:36 am   #4
mole42uk
mole42uk's Avatar
Mine seems to be an early one, it has a canvas case but looks otherwise just like the one detailed in the link above.
I bought it because no-one else wanted it at a tools auction, and I liked it because it has "PERCENT EXPLOSIVE" on the meter dial. That attracted the schoolboy in me!
Richard
Index:
mole42uk is offline
Old 16th Apr 2018, 9:18 am   #5
Dave Moll
Dave Moll's Avatar
Originally Posted by mole42uk View Post
I bought it because no-one else wanted it at a tools auction...
In that case I assume you paid somewhat less than the 198 quid in the linked page!
Old 16th Apr 2018, 12:14 pm   #6
mole42uk
mole42uk's Avatar
It was 196 cheaper.....
Richard
Index:
mole42uk is offline
Old 16th Apr 2018, 12:22 pm   #7
mole42uk
mole42uk's Avatar
I'd love to see that if you have time!
Richard
Index:
mole42uk is offline
Old 16th Apr 2018, 1:35 pm   #8
ISTR that these had a piece of metal hanging down, so that it would cause ripples when it hit water. It was then time to stop lowering the probe before it sucked in water.
Keep the soldering iron hot.
Station X is online now
Old 16th Apr 2018, 1:41 pm   #9
mole42uk
mole42uk's Avatar
Mine has that piece of metal. I wondered what it was for.
Richard
Index:
mole42uk is offline
Old 16th Apr 2018, 2:44 pm   #10
Dave Moll
Dave Moll's Avatar
Yes, that's the sort of price when I start feeling sorry for a vaguely interesting lot on the basis that I've not lost much even if it proves useless.
Old 16th Apr 2018, 6:36 pm   #11
qazxsw123
the sensor is a heated wire, in a bridge cct. the resistance of the wire changes when the gas is passed over it thus altering the bridge and changing the display on the meter. they take a load of U2 1.5v batts. the switch and meter will have a batt test position. the sensor is damaged by the petrol vapour that leaves a coating on the wire. there was a filter unit to be inserted in the sensor line if petrol contamination was expected. and yes when a petrol tank in a garage leaks it finds its way into the cable ducts.
you should be able to test it using the gac cooker, just turn it on for a second and then test the air around it.
qazxsw123 is offline
