Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Offered and Wanted Messages > Repair and Restoration Services Wanted
Repair and Restoration Services Wanted If you need someone to repair or restore equipment for you please post your request here.
Old 6th Apr 2018, 9:14 pm   #1
1955APREN
Default Gear4music ME502 mixer
Any one in the north shropshire. north staffs area willing to take on this repair
unit belongs to a friend of mine . is dead at first no voltage out of the power supply. No screws in power supply so case had to be broken, inside was just a
240v/ 20/0/20 transformer with the thermal fuse oc. I was able to short out the thermal just to test off load I had 20v on each side of the winding But when connected to the the mixer the transformer got very hot quickly.Removed bottom
of mixer But it is all sma one of the ic looks burnt . Not able to go any further with repair, not got equipment to remove these small components. Pleased to hear if any one can help.
Thanks Derrick
1955APREN is offline
Old 7th Apr 2018, 11:54 am   #2
Ancient Geek
Default Re: Gear4music ME502 mixer
What a coincidence. I've just started a repair on an Alesis mixer, also with burnt SMD components causing a PSU short. Sadly, I'm too far away to help, being in South Gloucestershire, but good luck finding someone.
Ancient Geek is offline
Old 7th Apr 2018, 3:14 pm   #3
sortedradio
sortedradio's Avatar
Hi Derrick,
I have an audio repair business based in Sheffield, but it's probably not economic to repair. They only cost 30 new, and it's likely to cost at least that plus parts to repair.
Martin
BVWS member
GQRP Club
sortedradio is online now
Old 8th Apr 2018, 7:58 am   #4
1955APREN
Thanks Martin
I will pass that information on to the owner
Regards Derrick
