Old 14th Nov 2015, 8:24 pm   #21
Station X
Station X's Avatar
Default Re: 'Proper' multimeter (Maplin MT2017)
For ten quid I'd have put up with a non-functioning continuity buzzer or tried to fix it.
Graham. Forum Moderator
Station X is offline
Old 15th Nov 2015, 12:27 am   #22
emeritus
I collected one of these today, a great meter for the price. I see the manual refers to an adaptor MT-2007-C for measuring capacitors smaller than 25 microfarads. Maplin do not list this item, and while Google does find it on the Proskit web site and in a 2009 Proskit catalogue, for suppliers it only found a stockist in Thailand and an obsolete parts specialist in the USA. Does anyone know what the adaptor does, and if it would be possible to construct a substitute? I assume it must include some sort of oscillator. It would be useful to be able to measure capacitance.
emeritus is offline
Old 16th Nov 2015, 6:01 pm   #23
60 oldjohn
Just been it my local Maplins for a MT2017 meter, sold out as we know. Good news, new stock expected around 26th Nov. I have paid my £9.99 and it will be delivered for that price.
John.
60 oldjohn is online now
Old 25th Nov 2015, 4:03 pm   #24
grampy2
I had an interest in getting ng another one,so ordered again when I was emailed to say they were in stock again,I've just collected it today and every thing works. Also the battery case is different and it's very easy to put the batteries in.
grampy2 is offline
Old 26th Nov 2015, 1:37 pm   #25
Herald1360
Herald1360's Avatar
Be interesting to know how much effect this forum has had on Maplin's sales of these
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is online now
Old 26th Nov 2015, 4:49 pm   #26
60 oldjohn
There are other sellers of the MT2017, I've just seen one on the net for £56+ inc free postage. Mine has just arrived, the new style MT2017 has the 10amp socket between the + & - V sockets and has the improved battery access. Overall not a bad meter for £8.33 + vat & free postage to me. Maplin have triumphed with this one, maybe a "loss leader" I wonder how long present stocks will last with all our publicity?
John.
Old 8th Jan 2016, 6:03 pm   #27
Alvin
Alvin's Avatar
I've also 'gone green'. I ordered one on line for pick up at local Maplin store and collected it today. Haven't yet found anything I don't like about it!
Alvin
Alvin is offline
Old 9th Jan 2016, 4:16 pm   #28
russell_w_b
russell_w_b's Avatar
No a.c. Amps measurement?
Regds,
Russell W. B.
G4YLI.
russell_w_b is offline
Old 2nd Apr 2016, 8:17 pm   #29
neonlamp
Looks interesting. Maybe if my Avo8 dies...
But I also had a £5 Maplin DMM and the only issue I can see that is common is that the leads have long exposed tips. Having shorted components when measuring, I would always recommend sleeving the test lead probe tips to within about 2mm.
neonlamp is offline
Old 16th Mar 2018, 1:31 pm   #30
Station X
Station X's Avatar
Now only £6.99!
https://www.maplin.co.uk/p/mt-2017-l...ltimeter-n60lk
I just bought another one. The two should last me out.
Old 16th Mar 2018, 5:13 pm   #31
winston_1
I've just ordered one as well. Be stupid not to. Also ordered a 17 piece phone repair kit.
winston_1 is offline
Old 16th Mar 2018, 5:36 pm   #32
David G4EBT
David G4EBT's Avatar
No mention in the spec as to the DC Sensitivity.
IE: 1,000/2,000/10,000/20,000 Ohms per Volt?
20k would be nice.
Won't matter for some applications, (to peak a tuned circuit etc) but it will when, for example, measuring low voltages across potential dividers.
Maybe there's a reason that the sensitivity isn't mentioned in the spec, as in: 'don't draw attention to limitations'?
The µA & mA scales are very cramped, but then that's due to the compact size.
I guess most users would resort to a digital meter for measuring current.
The specs wrong anyway - it states: 'DC current from 250mA to 10A'.
Unless my eyes are deceiving me, there's a 50µ range, then 2.5 mA, 250mA, and via a separate socket, up to 10Amps.
But for seven sovs, best not get too picky.
David.
BVWS Member.
G-QRP Club member 1339.
David G4EBT is offline
Old 16th Mar 2018, 5:48 pm   #33
bikerhifinut
I magnified the image David, 20k/V DC and 9k/V AC. Not too shoddy I'd say!.
Which ties in with the observation of a 50uA range.
Andy.
bikerhifinut is offline
Old 16th Mar 2018, 5:52 pm   #34
Looking at one of mine (I have three) the sensitivity (written on the scale) is 20k/volt DC and 9k/volt AC. Currents are 50u, 2.5, 25 and 250 switched plus the 10A socket.
A couple of useful additions to your 'normal' analogue mater are a beep continuity test, instantaneous in operation (unlike lots of DMMs) and a handy +/- 5V and 25V centre zero range which you can swing a couple (10 on 25V) of volts either way with the zero ohms pot.
I was impressed at £10.
Old 16th Mar 2018, 5:53 pm   #35
ms660
ms660's Avatar
The 50uA current range is also an indication of the Ohms Per Volt...
Lawrence.
ms660 is offline
Old 16th Mar 2018, 5:58 pm   #36
I missed the ballistic capacitance scale and the transistor testing ability.
Old 16th Mar 2018, 6:01 pm   #37
David G4EBT
Thanks guys.
Looking again at the picture, the sensitivity can just be seen below the red notice 'Fuse & Diode Protection', bottom LH of the dial.
As has been stated, 20K OPV DC, 9K OPV AC.
Can't complain at that!
David.
BVWS Member.
Old 16th Mar 2018, 6:09 pm   #38
MrBungle
MrBungle's Avatar
I know this is possibly teetering on the edge of the eBay rules, but they are selling them on ebay still from Maplin's Outlet at £6.99 as well + £2.99 delivery (same as online price). At least if you pay though there and it doesn't turn up, you can get your money back via paypal.
MrBungle is offline
Old 16th Mar 2018, 6:16 pm   #39
And if you buy more than one it's still £2.99 postage, I keep telling myself I don't need more than three. Another advantage of 20k/V is that is matches the readings on vintage radio data sheets.
Old 16th Mar 2018, 6:32 pm   #40
MrBungle
MrBungle's Avatar
I blew mine up within a week of getting it so YMMV on that "three is enough" estimate
MrBungle is offline
