Old 15th Nov 2018, 10:48 pm   #1
squegging
squegging's Avatar
Default DC motor speed control
I am trying to fix a potters wheel for a friend. Basically, it runs, but at the slow setting it still runs too fast.
The motor has EMD marked on it and has brushes / commutator. So I suppose it runs on DC? There is also a tacho.
The control pcb has mains to it, and has I think, two 2N3525 SCR's but no makers name/ part number to identify it. The speed control is by a 5k pot mechanically linked to a foot pedal. The pot track / wiper checks out ok.
I attach some pictures in the hope someone may recognise the kit and perhaps provide a circuit to enable diagnosis?
Any help most appreciated....
ID:	172883   Click image for larger version
Name:	EMD Motor.jpg
ID:	172884   Click image for larger version
squegging is offline
Old 15th Nov 2018, 10:51 pm   #2
Radio Wrangler
Radio Wrangler's Avatar
Default Re: DC motor speed control
Could be a universal motor. Nothing unusual. Most washing machines have motors with brushes running on AC controlled by a tacho.
Radio Wrangler is online now
Old 15th Nov 2018, 11:00 pm   #3
squegging
squegging's Avatar
I'm not too hot on motors....
Apart from the tacho (2 wires) it has 4 wires to from the controller. Is that any sort of clue?
Old 15th Nov 2018, 11:26 pm   #4
McMurdo
McMurdo's Avatar
EMD is Electric Motor Developments, no longer trading. Several potters wheels here in Staffordshire used them, though I've never seen one like that before with a tacho. All the ones I've fixed (and I've fixed very many!) had dc shunt motors on them, no tacho. A universal motor of course is not so easily reversed!
Kevin
McMurdo is offline
Old 15th Nov 2018, 11:48 pm   #5
squegging
squegging's Avatar
Well, this setup has a DPST switch connected to the controller which reverses the motor. So does that suggest its a DC motor?
Also what sort of speed would be acceptable on slow setting?
Last edited by squegging; 15th Nov 2018 at 11:49 pm. Reason: extra question added about speed
Old 16th Nov 2018, 12:18 am   #6
McMurdo
McMurdo's Avatar
Don't know how that would work but if the motor reverses then it must be either an ac induction motor (no brushes) or a DC motor.
I'd have guessed all the way to standstill with the pedal backed off.
Kevin
McMurdo is offline
Old 16th Nov 2018, 1:56 am   #7
Radio Wrangler
universal motors reverse if you reverse the connactions to either the brushes, or to the field (just not if you do both!)
4 wires from the motor to the controller would allow this.
Old 16th Nov 2018, 10:56 am   #8
squegging
squegging's Avatar
I have just measured 110vdc (slow) to 220vdc (fast) across the brushes, and 17vdc (slow) to 18vdc (fast) across the field.
When the direction switch is operated, the field changes polarity.
So now to start tracing out the circuit.... could be a while. Watch this space!
Old 16th Nov 2018, 12:59 pm   #9
Two pots on the control board, min and max speed?
Old 16th Nov 2018, 3:16 pm   #10
Skywave
The photo of the pcb, top left, shows a transformer that looks like it is designed for 50 Hz operation. Just above it, I think I can see 4 diodes. Also, there a few electrolytic caps. in that region too. To me, all that suggests that the controller - and thus the motor - is operated from d.c.
With that in mind, merlinmaxwell's above comment seems possibly relevant.
Al.
Skywave is offline
Old 16th Nov 2018, 5:29 pm   #11
Ed_Dinning
Is this motor directly coupled to the wheel, or through a belt/ gearbox system?
If that is the case and you do not need the max speed, alter the drive ratio.
Ed
Ed_Dinning is online now
Old 16th Nov 2018, 5:51 pm   #12
thermionic
thermionic's Avatar
Hello.
Before delving in too deep, try removing the 1/4 watt resistor from the choc block connectors. I agree with Merlin, the two presets are for minimum and maximum speed settings.
It could be that someone has ‘ modified ‘ the unit by fitting this extra resistor.
Good luck!!
SimonT.
The honesty of imperfection..........
thermionic is offline
Old 16th Nov 2018, 6:14 pm   #13
ex seismic
Two pots on the board, both set at the end of their travel. Suspicious?
ex seismic is offline
Old 16th Nov 2018, 7:27 pm   #14
wave solder
wave solder's Avatar
The resistor fitted in the terminal block could just be a pull down resistor just in case speed control input goes open circuit.
wave solder is offline
Old 16th Nov 2018, 8:34 pm   #15
Boater Sam
Check that the tacho magnet is properly secured, we have found many that are loose so the tach doesn't get up to speed.
Boater Sam is offline
Old 17th Nov 2018, 11:44 am   #16
squegging
squegging's Avatar
Ed,
There is belt dive reduction using two "fan belts". Smaller pulleys x2 64mm running dia, larger ones x2 241mm running dia. So I reckon overall the ratio is 14.18:1. So plenty of torque on the turntable. Not so easy changing gear!
And thanks everyone else for your interest and suggestions. There are indeed two pots L & H which I haven't yet touched, but will give them a good twiddle to ensure their wipers are ok when I can get back to the job.
Old 17th Nov 2018, 11:48 am   #17
squegging
squegging's Avatar
Yes, The magnet is firmly secured.
Old 20th Nov 2018, 11:49 am   #18
squegging
squegging's Avatar
Merlinmaxwell hit the nail on the head. When I originally got the job, there was no speed control at all. The wiper of the main speed control pot linked to the foot pedal was not making contact. After cleaning it up, there was some reduction in speed, but not enough.
Tweaking the two pots on the pcb meant that I could now bring the motor to a standstill. Problem solved.
Old 20th Nov 2018, 3:26 pm   #19
Thank you, I am glad it worked!
