Old 15th Dec 2018, 4:06 pm   #21
Goldie99
Default Re: Wadar chassis nightmare! Suggestions?
Maybe too late at this point, but I would have considered asking some of the Classic / Vintage Motorcycle specialists, e.g, 'The Finishing Touch', https://www.classicmotorcyclepaintwork.com/.
I've no connection, but have used this particular company in the past for a complete (2-pack) respray on a classic Norton, including transfers & lining, and was extremely pleased with the result.
Goldie99 is offline
Old 15th Dec 2018, 6:06 pm   #22
Ian - G4JQT
Ian - G4JQT's Avatar
Out of interest, how has clear lacquering the front panel caused the transfers to be damaged? mishandling? chemical reaction? being rubbed off between coats? Anyone on here could do better than that.
I think it was the rubbing down between coats.
Yes, I could have done a bit of research and done it myself. It couldn't have been worse, and even if it was it wouldn't have cost anywhere near as much!
Ian - G4JQT is offline
Old 15th Dec 2018, 6:50 pm   #23
What paint did you specify? Two-pack isocyanate or one of the modern nasty water-soluble things?
Professional vehicle-painters only "rub down between coats" if they truly screwed-up and have to remove runs/orange-peel before recovering.
And how were the labels applied? Assuming there's a 'clear-coat' been applied over the top, unless the labels are known to be compatible with the solvents in the clear-coat, I'd expect there to be some degree of 'lifting'.
To solve the issue, I'd have the whole thing stripped back to bare metal and the front panel engraved with the logos. Then etch-prime and two-pack. Then fill the engraved logos with an appropriately-coloured oil-based paint (so as not to react with the two-pack).
Alternatively, have an entire front-panel made from black Traffolyte, with suitable engraving. If you've got anywhere local that does engraving for sports-trophies etc they will have the equipment [and the Traffolyte] for this. They charge per-letter.
Old 15th Dec 2018, 7:08 pm   #24
stevehertz
stevehertz's Avatar
They are sooo ham fisted. I mean, surely anyone could have seen the potential to remove those transfers by rubbing down?
Anyway, too late now and my sympathies are with you. I have suffered many times at the hands of 'experts' and 'specialists' doing work for me. I mostly do all my own work now be it spraying, woodwork renovations, electronics (obviously), in fact anything that requires a bit of brain power to put it bluntly. Otherwise I have a list of 'recommended by friends' service providers for general household stuff mostly who I have been using for years. And I never just refer to ads or lists to find a service provider. I just made the acquaintance of a 'new' car mechanic last week, after my last one who had stood for forty years retired in April.
stevehertz is offline
Old 16th Dec 2018, 7:49 am   #25
Argus25
No Longer a Member
Originally Posted by Argus25 View Post
It is very hard to beat nitrocellulose for its amazing shine.
The first page if this article shows a couple of my guitars that both have nitrocellulose lacquer:
http://worldphaco.com/uploads/Gretschdoc.pdf
Argus25 is offline
Old 16th Dec 2018, 8:44 pm   #26
Heatercathodeshort
Heatercathodeshort's Avatar
Very difficult one. Pity about the treble mess. I would be tempted to make a smart aluminium plate that would mount under the control locking nuts. Give it a high polish then lacquer it.
You don't need to label the controls but if you must, why not get them engraved on the plate? Just a suggestion.
Heatercathodeshort is offline
Old 18th Dec 2018, 9:33 am   #27
high_vacuum_house
high_vacuum_house's Avatar
Just an idea but why not engrave the wording on the knobs and keep the chassis clean. This is what some manufacturers did i.e Bush Bakelite tellies.
Christopher Capener
Interests in the collection and restoration of Tefifon players and 405 line television
high_vacuum_house is offline
Old 18th Dec 2018, 4:21 pm   #28
Heatercathodeshort
Thinking about it, do you really need to label the controls at all? Maybe just a high quality plate is sufficient. J.
Old 19th Dec 2018, 9:57 am   #29
Heatercathodeshort
If it helps the original Wadar amp did not have lettering for the controls. The control knobs themselves are numbered 0-10 giving a very smart, clean appearance to the amp.
This was one of the last amps built by Gerry.
Your paint job is excellent. It is VERY difficult to get a flawless finish on these chassis so I would be tempted to leave it alone. Give it a poke and the floor will collapse..
Regards, John.
Old 19th Dec 2018, 10:45 am   #30
Ian - G4JQT
Thanks all for the additional thoughts.
I'm still minded to go for silver plaques/black lettering to hide the decals. Or maybe as some have suggested silver or anodised plates for the front of the transformer cover and front panel with appropriate lettering, once I've found a suitable company.
Halfway through this fiasco it did occur to me to not have any lettering and just have the knobs engraved. That would have been quite adequate.
Oh well, this is a First World problem as they say. I'm very fortunate to have this as the only thing to worry about right now...
Ian
Old 19th Dec 2018, 11:48 am   #31
antony07
I know a guy called Gav, his paint, finish and detail is second to none. If you want it done properly, you should speak to him. PM me and i'll give you his contact details if you're interested. Thanks Antony
antony07 is offline
