10th Aug 2018, 9:17 pm | #21 |
Re: Nickel Cadmium vented cell battery, advice sought
NiFe cells were also used on Class 321 four car trains as back-up power for lighting. I was recently gutted when working on these trains at Milton Keynes where they had hundreds destined for scrap. I wanted quite a few for my solar PV project but couldn't get them because I don't have a waste disposal license or transport. If i'd known before the job finished I probably could have had the lot. All they needed was a clean up and fresh electrolyte. I hope the scrap dealer who got them knew what they are worth.
Richard |
10th Aug 2018, 9:20 pm | #22 |
I had one of them NiFe cells, it came from a mines backup lighting system, I just got the one for lighting glowplug on a model engine.
worried about the electrons entering the circuit and the smoke leaving Andrew |
10th Aug 2018, 9:23 pm | #23 | |
Richard |
10th Aug 2018, 11:08 pm | #24 |
Shouldn't that be the other way around? In any case, the voltages are very similar so it might not be easy to identify them that way.
10th Aug 2018, 11:27 pm | #25 |
You could be right.
Richard |
11th Aug 2018, 11:59 pm | #26 |
Just had another look through my 1940's book ("Accumulator Charging", W.S.Ibbotson, Pitman, 7th Edition, 1941). Confusingly, the Nickel-Iron cell is referred to as the "Edison Nickel-Iron Alkaline Cell", or Edison cell for short, while the Nickel-Cadmium cell is called the " "NIFE" Nickel-Cadmium Cell ", or "NIFE" cell for short. "NIFE" always appears in quotes, suggesting it might at that time have been used as a trade mark for Nickel-Cadmium batteries and not, as the letters in quotes suggest, Nickel-Iron batteries. It is therefore possible that the NIFE batteries that other posts have mentioned as having been used in electric vehicles were actually Nickel-Cadmium batteries. Externally, they seem to be pretty well identical.
12th Aug 2018, 11:08 am | #27 |
So "NIFE" was a trademark used for various chemistries but NiFe is specifically Nickel Iron.
Presumably NiFe couldn't be registered as a trademark any more than ballpoint as opposed to "Biro".
12th Aug 2018, 12:31 pm | #28 |
If I remember correctly, a few Australian aviation ground DME's used a 42 volt battery of "NIFE" brand wet nickel cadmium cells, some up until about 1990, as standby power.
They were rugged and reliable, and would last almost forever. They were about 30 x 100 mm and about 250 mm high, in a light blue plastic case. I had to clean up a bank once in North Queensland. I seem to remember they had terminal posts with an unusual thread (for its day), ie BSF, as I had to buy a tap and die-nut. And we refilled the electrolyte. A special hydrometer was used, not so much for checking state of charge, but to make up the replacement electrolyte. |
14th Aug 2018, 11:41 am | #29 |
I'd recommend pipetting over electrolyte to keep plates covered. You really do need to SG measure each cell to determine if it is just evaporation over time (my expectation). You have to use a clean pipette and if SG is high then add battery grade deionised water. The cell voltage and temp and SG will confirm the cell type.
NiCd like these were used in some high-grade applications, back in the days when 20+ yr service life was a requirement. |
