Old 7th Aug 2018, 11:34 am   #1
Porkchop
Default Marconi 2018 help needed
Thanks for opening my thread! Here’s my issue:
I have a Marconi 2018, not the A version. It has been working fine until recently. I purchased an HP 8924C that I’ve been using to do alignments with on radio equipment, so I haven’t used the Marconi in a few months. Even though it displays incorrectly, it is still generating the correct frequency and modulated signal.
When I turn the unit on, an 8 is displayed in the carrier frequency window for a brief few seconds, followed by an 823. When the starting frequency is displayed, 520.0000, it shows as 520.80000. If I change the frequency to say, 27.185 then 27.87500 is displayed. However, the output is actually 27.18500 like I entered. Checking this with a known working radio connected confirms this. It seems to function correctly except for the 8 that continues to be displayed.
I have no repair shops nearby, I have no service manual and I have no idea what’s wrong with it. Can anyone help me out on this? I use the HP often but now and then I’d really like to be able to continue to use my Marconi. I know this is a UK based forum but searching for help via Google didn’t really turn up much here in the US. Any help would be greatly appreciated.
Thanks!
Porkchop is offline
Old 7th Aug 2018, 12:05 pm   #2
Station X
Station X's Avatar
Default Re: Marconi 2018 help needed
If you PM me your email address I'll email you the service manual.
Graham. Forum Moderator
Station X is offline
Old 7th Aug 2018, 12:38 pm   #3
Porkchop
Alright, I’ll do that. Thank you.
Porkchop is offline
