1st Aug 2018, 7:03 pm | #1 |
Unknown DIL component ID
I recently obtained a couple of tubes of these components but have no idea what they are. Before I start testing them to try and find out, I was wondering if anyone actually recognizes them ? Google searches have provided no clues. Andy |
1st Aug 2018, 7:09 pm | #2 |
Re: Unknown DIL component ID
Transformer.
1st Aug 2018, 7:10 pm | #3 |
Agreed
1st Aug 2018, 7:16 pm | #4 |
Possibly a BALun, then?
1st Aug 2018, 7:24 pm | #5 |
I've seen these mostly on PC Ethernet cards so it probably contains four transformers.
Ian |
1st Aug 2018, 7:44 pm | #6 |
Possibly delay lines - not enough pins for 4 transformers but could be 3
J |
1st Aug 2018, 8:07 pm | #7 |
I would go with a delay line. We used to use a lot of small BAL delay lines that looked a lot like that in a professional video company I used to work for in the 80s.
Chris |
1st Aug 2018, 9:29 pm | #8 |
They also look as if the top cover can pop off - maybe an opportunity to show us the insides - even if it is 'only' a transformer.
1st Aug 2018, 10:43 pm | #9 |
Hi!
http://www.allenavionics.com/V_Delay/BAL10_30.htm I'm hazarding a guess that the part no. you've shown means a 10MHz base type and the final digits are the nominal delay in nanoseconds – B10995 = 10MHz series, nom delay = 995ns. Any help? Chris Williams
It's an enigma, that's what it is! This thing's not fixed because it doesn't want to be fixed! Last edited by Chris55000; 1st Aug 2018 at 10:52 pm. |
2nd Aug 2018, 7:44 am | #10 |
Thanks guys, this is all very helpful !
Taking resistance readings across the pins gives low values of less than one ohm across many of the pins, so transformer(s) made sense. I don't know anything about delay lines : what they contain or how they function so am not sure what sort of readings to expect in this case. Last night, I decided to saw the top of one to find out what was inside... unfortunately it's completely filled with resin and even taking the top half off revealed nothing. If this was a transformer I'd expect to find some cores but whatever this is, the main parts must be on the base and be very small. I will start to chip away at it later on today to see if anything further is revealed. Andy Last edited by radioman; 2nd Aug 2018 at 7:45 am. Reason: Typo |
2nd Aug 2018, 12:01 pm | #11 |
Thanks Chris for that BAL link - it certainly appears to be a delay line.
I took one apart this morning... see pictures below. First components to be found were some SMD capacitors - I measured one at 200pF, these were connected to most pins and then to a central common connection. When the caps were removed there was a strip of waxed paper and beneath this was an encapsulated inductor as I could see some windings at one end. As this sacrificial one was now too damaged to take any readings from, I got another and determined that it has a single multi-tapped inductor with a total inductance of ~14uH (DCR=3.5R) although this is probably inaccurate due to the capacitors in circuit. Not sure what I'll do with them now (I've got 49 left) - any suggestions ? Are they still used nowadays ? Andy |
2nd Aug 2018, 4:12 pm | #12 |
I certainly have used them 'within living memory'.
More seriously, RS and Farnell stock delay lines, albeit in surface mount (SOIC, etc) packages with internal buffers to make them easy to interface to logic ICs. So I guess they are still used in modern stuff. |
5th Aug 2018, 7:54 pm | #13 |
I once made a single transistor phase shift oscillator with a delay line like that. It was just a demo board and was just put to one side after I had a play with it.
5th Aug 2018, 10:01 pm | #14 | |
John
GQRP Club 4704 - BVWS Member |
5th Aug 2018, 11:13 pm | #15 |
We made DIL delay lines and filters like that when I was a trainee at a place supplying components for the nascent digital broadcast equipment industry, late 1980's.
Ours were rather better made though, with a tiny custom pcb inside containing the SMD and any inductors wound on tiny bobbins or toroids. One of my jobs as a junior was soldering the pcb into the DIL header, glueing the lids on with epoxy, mixing a batch of potting compound, getting rid of any air in the vacuum chamber and finally potting them. This type of thing is very labour intensive and they didn't come cheap.
Kevin |
