Old 10th Aug 2018, 9:56 am   #61
crackle
Default Re: Oil for sintered bearings
Maybe you need to replace the felt oil pad, it is likely it has been compressed and is adding too much friction when the brass collar is done up so the oilite bearing can't swing into correct alignment.
As I mentioned before a gentle tap on the shaft or flywheel can help these self aligning bearings to align. But be sensible about where and how hard you tap it.
Mike
crackle is offline
Old 10th Aug 2018, 10:20 am   #62
dseymo1
An approach I have taken in the past, but hesitate to recommend unless you are sure you can do it safely, is to loosely reassemble the motor, then power it up and carry out final asembly while it is running. It will tend to self-align, and any problems due to unevenly torqed fixings, for example, are immediately evident.
dseymo1 is offline
Old 10th Aug 2018, 11:03 am   #63
wd40addict
wd40addict's Avatar
Hi Guys, not given up on this, but oil I ordered is taking forever to come
wd40addict is offline
Old 17th Aug 2018, 12:55 pm   #64
wd40addict
wd40addict's Avatar
OK, progress so far: Unfortunately I had to wrap this up a bit quicker than I would have liked due to a sudden influx of relatives!
In the end I used REGZ22 oil which is allegedly 10 SAE with no additives and comes with an amazing spout. It's possibly too thin meaning gravity plays a part, but time was against me.
Anyway, I soaked the felt pads in the oil and reassembled the bearings. I nipped the lock nuts up tight-ish, but did not centre punch them. They were thus fairly free to self align. I then re-installed them in the machine and then kept running it, occasionally stopping it to apply more oil courtesy of amazing spout. This was slowly absorbed and the flywheel is now free running like never before.
Access once installed is so poor I couldn't use Graham's suggestion of tightening in situ.
If I had to do it again I'd probably try soaking the oilites in additive free SAE 30 for 24hours, with heat if possible.
I would also echo the advice given above in the thread about not oiling unless necessary. The oilites on my Cossor flywheel are still working fine after 60 years.
Old 17th Aug 2018, 10:02 pm   #65
NorfolkDaveUK
I use machine oil. It works. I don't know what people look for the "ultimate oil" just service and clean regularly and then it won't matter what the heck you use.
NorfolkDaveUK is offline
