26th Jul 2018, 9:00 pm | #1 |
Evershed & Vignoles Insulation & Continuity Tester,Series 2 - how to disassemble?
Hello
I have one of these unit and I can see no way to take it apart - anyone any ideas? Thanks TYJ
"If we are not going to make things, what are we going to do?" Fred Dibnah |
26th Jul 2018, 9:45 pm | #2 |
Re: Evershed & Vignoles Insulation & Continuity Tester,Series 2 - how to disasseble?
If it's the one I'm thinking of, screws under the rubber feet on the bottom?
Andrew
26th Jul 2018, 10:39 pm | #3 |
If it's the alloy bodied one you could encounter siezing. (if so,various strategies apply, possibly the best of which is pre-heat with a soldering iron to crack the corrosion, then penetrating oil of some sort)
29th Jul 2018, 5:50 pm | #4 |
Thanks guys for the replies.
You know anytime I post on here thinking I have a bit of spare time I post and something always takes me away - very frustrating ! However I did find out that it is not a series 2 but the earlier "Meg Tester". The Meg tester does not have individual rubber feet but bars screwed on the bottom. As I did not have time for heat I gave them a good soak with penetrating oil. We'll see what happens! Thanks TYJ
29th Jul 2018, 9:00 pm | #5 |
There was a thread last year about the Series 2 with a couple of useful pictures:-
https://vintage-radio.net/forum/show...63&postcount=1 I don't think there's a huge difference between the 'Meg Tester' and the Series 2. My Series 2 has bars on the bottom as well, held by copper plated screws into blind tapped holes, but doesn't have a removable bottom plate as shown in the link above. The only access is via the end cover, which is retained by slotted nuts hidden under lead seals. It's a long time since I took mine apart, but I also remember being surprised by the long spring like connectors shown which extended as the two parts were separated. Cheers |
30th Jul 2018, 8:41 pm | #6 |
Trigon
Thanks for the link however, I don't think the bottom comes off of mine - so its back to the lead covered screws. Can you recommend a way of removing the lead covering so I can get to the screws? Thanks TYJ
30th Jul 2018, 9:20 pm | #7 |
I think I just stuck a very sharp scriber into the middle of a seal and levered it out.
I doubt that there's a way of removing them without destroying them - they wouldn't be very useful as anti-tamper seals if there was! Cheers. |
31st Jul 2018, 7:54 pm | #8 |
Trigon
I was considering that as an option but it is always nice to know that someone has had success doing that. The good news I guess is that it should have kept the damp out! Thx again TYJ
1st Aug 2018, 1:30 am | #9 |
Re: Evershed & Vignoles Insulation & Continuity Tester,Series 2 - how to disassemble?
They do indeed come out with a sharp scribe.
