Forum Announcements and Comments Announcements about forum changes will be made in this section. All new threads here now require moderator approval. |
17th May 2018, 8:54 pm | #1 |
Administrator
Mark Forums Read
Someone at the NVCF asked if I could add "Mark Forums Read" to the top menu bar as it is difficult to access in "Quick Links" on mobile devices. This is now done.
17th May 2018, 9:07 pm | #2 |
Re: Mark Forums Read
I wasn't that person, but thank you - it is certainly a function I use every time I look at the forum(s) after looking at those threads I consider of interest, so this will save me having to go into "Quick Links" and selecting it from there each time.
17th May 2018, 9:24 pm | #3 |
Unfortunately it is now very easy to click on this link unintentionally, especially as it is adjacent to the New Posts link. (Guess how I know that?) There is no confirmation prompt. I will be more careful in future, but I can see this causing more problems than it solves.
17th May 2018, 9:41 pm | #5 |
Whatevers happened I don't like it
It's changed the whole format. Maybe just me. Cheers Mike T
17th May 2018, 9:46 pm | #6 |
The revised location is an improvement.
17th May 2018, 9:52 pm | #7 |
Maybe me but I don't find anything about this an improvememt.
Cheers Mike T
17th May 2018, 9:54 pm | #8 |
Administrator
Can you post a screenshot if it looks odd for you Mike? What browser are you using?
Attached is how it looks for me with Firefox. |
17th May 2018, 11:26 pm | #9 |
It was my suggestion and it's a great improvement.
Well done Paul. |
18th May 2018, 6:50 am | #10 |
I had not noticed the change until I saw this thread and it seems I never ever do anything from the top bar - even for search there is a separate box and why would you ever want to log out... As long as you keep the existing one at the bottom I am happy.
Dave |
18th May 2018, 5:56 pm | #11 |
Administrator
I have added a confirmation on the "Mark Forums Read" on the top bar now, to reduce the risk of doing so accidentally.
18th May 2018, 6:06 pm | #12 |
Ugh. It is actually less likely to be done accidentally than it was as a drop-down.
18th May 2018, 7:13 pm | #13 |
Administrator
OK, since every variation of this attempt to help has upset someone, I have put it back as it was originally - just in the Quick Links dropdown. I can't be bothered to waste any more time with it.
