Old 30th Jun 2018, 3:38 pm   #21
ntscuser
ntscuser's Avatar
Default Re: Interesting UHF aerials.
Here's the rare double-Parabeam which takes advantage of the 'skeleton slot' radiator to couple two Yagis together:
Classic TV Show Theme Tunes
ntscuser is offline
Old 3rd Jul 2018, 1:08 pm   #22
SteveCG
Re: post no. 19
I am certain that it is a J. Beam, MK 1 PBM 10 for Group C.
SteveCG is offline
Old 29th Jul 2018, 8:34 am   #23
Heatercathodeshort
Heatercathodeshort's Avatar
An incredible mix of CP and Midhurst aerials seen from the car park in Cranleigh village Surrey. J.
Name:	Cranleigh 27-7-18. Aerials..jpg
Heatercathodeshort is offline
Old 29th Jul 2018, 8:41 am   #24
Heatercathodeshort
Since the reallocation of the top end channels on UHF an amazing number of log periodic aerials have appeared on the rooftops around the Horsham area. The second shows another at Warnham.
This newly installed one, believe it or not is situated 2mins walking distance from the Crystal Palace transmitter. J.
ID:	166708   Click image for larger version
Old 29th Jul 2018, 8:53 am   #25
Heatercathodeshort
Midhurst and Guildford relay here together with the remains of an old box 8 channel 9 to Croydon or maybe Chillerton Down. Seen on large houses in Cranleigh High St.
The three in a line aerials are wired to separate parts of the house. [Midhurst] J.
ID:	166710   Click image for larger version
Old 29th Jul 2018, 1:19 pm   #26
G4_Pete
This is my favourite TV areal high in the welsh hills near the very remote village of Dylife approximately nine miles north west of Llanidloes. I have always presumed it to be some sort of TV repeater. There is only a small junction box at the base and no sign of cables or another pick up areal that I have found. The farm is the closest building and that is a long way away as I was zoomed in.
Favourite for 2 reasons one it means I am on horseback in the welsh hills and secondarily it means that after a full day of riding we are on the right track and will reach the destination in another hour or so.
Pete
Name:	near village of Dylife.jpg
G4_Pete is offline
Old 29th Jul 2018, 2:08 pm   #27
DIY repeaters are common in hilly areas, one aerial pointing to the transmitter another pointing to the village with a masthead amplifier twixt, all powered from a knackered tractor battery. The hill gives enough attenuation to prevent feedback.
Old 29th Jul 2018, 4:34 pm   #28
Heatercathodeshort
It maybe is feeding one of those trendy underground houses.. J.
Old 6th Aug 2018, 10:58 pm   #29
nigelr2000
nigelr2000's Avatar
Went for lunch in Debenhams in Norwich on the 3rd floor and sat near a window, I spotted this aerial on the building opposite, looks like the one my supplier called a BBQ aerial as sideways it would make a good BBQ with the x shaped dipoles good for sticking sausages on LOL, I believe it was good for ghost rejection with the 4 x's in a row on the front with the large reflector. The windows were all sealed shut so the pictures a bit indistinct as the were a bit dirty.
nigelr2000 is offline
Old 7th Aug 2018, 9:19 am   #30
Hybrid tellies
Hybrid tellies's Avatar
I have a smaller version of this aerial in my loft for long distance UHF reception. Very high gained with good ghost or multipath rejection. They are also wideband covering the entire UHF TV spectrum.
Simon
BVWS member
Hybrid tellies is offline
Old 7th Aug 2018, 11:49 am   #31
winston_1
Those twin loop DER aerials were surprisingly good and wideband. There was one in the loft of my prievous house working well. I had another second hand for experimenting with. I eventually fitted it to the outside wall of a ground floor flat where access to the upper floor walls was unavailable.
winston_1 is offline
Old 7th Aug 2018, 1:01 pm   #32
Nuvistor
Nuvistor's Avatar
Wolsey Colour King by the look of it.
Frank
Nuvistor is offline
Old 18th Aug 2018, 8:18 pm   #33
Heatercathodeshort
Nothing illustrates the horrible situation of foliage attenuation more than these pictures taken in Leatherhead Road Chessington today. It was one of the biggest problems for me when we went UHF in 1969.
The houses either side of the problem have normal UHF aerials but the unfortunate two in line with dense tree foliage on the other side of the road are extended on high poles in an attempt to improve the scrambled signal. The trees are dead in line with CP behind.
John.
Name:	Foliage attenuation 1.jpg
ID:	167792   Click image for larger version
Name:	Foliage attenuation 3.jpg
ID:	167793   Click image for larger version
Name:	Foliage attenuation 2.jpg
Old 18th Aug 2018, 8:53 pm   #34
Nuvistor
Nuvistor's Avatar
I had a number of customers with similar situations and very difficult to overcome completely if at all.
Frank
Nuvistor is offline
Old 19th Aug 2018, 4:53 pm   #35
AJSmith625
Reception in this situation often became even worse during and after heavy rain when the tree leaves were soaking wet.
Alan.
AJSmith625 is offline
Old 19th Aug 2018, 4:58 pm   #36
Heatercathodeshort
Wind was also a nightmare with the swinging branches and leaves. Forget teletext and bringing us up to date, Digital. J.
Old 19th Aug 2018, 6:14 pm   #37
Vectamart
Vectamart's Avatar
Originally Posted by Dai Corner View Post
Lots for those interested in aerial photography here
http://www.wrightsaerials.tv/aerialp...hy/index.shtml
Very interesting and nostalgic set of photos. Just one small correction - the heavy UHF aerials with the grid reflectors were actually branded "Telerection" as opposed to Telefusion.
Vectamart is offline
Old 20th Aug 2018, 11:17 am   #38
SteveCG
re post no. 33
.... I just wish the rigger(s) had put better aerial(s) up, having gone to all that trouble with the poles and the tape ...
SteveCG is offline
Old 20th Aug 2018, 12:19 pm   #39
Scimitar
Scimitar's Avatar
Oh yes, see what you mean! £2 contractor aerials. Always the mark of a professional and expert installer, that.
Scimitar is offline
Old 20th Aug 2018, 1:11 pm   #40
SteveCG
Scimitar,
Indeed, the left hand one on the picture probably cost £1.50. I won't speculate on what the customer paid...
SteveCG is offline
