Reply
Old 5th Feb 2023, 6:15 pm   #3121
Sinewave
Sinewave's Avatar
Default Re: AVO Multimeter survey
Originally Posted by stickfly View Post
Sinewave,
Thanks for that but there's nothing in the battery compartment.
The AVO looks shiny & new but has nothing to identify it.
Much lighter than the earlier AVO's though & works well.
Regards ..... Gary
The sticker on the side identifies it, that's the serial and date code.
Avometer, vintage Fluke and Marconi collector. Also interested in vintage Yaesu and KW.
Sinewave is offline   Reply With Quote
Old 5th Feb 2023, 9:29 pm   #3122
Phil G4SPZ
Phil G4SPZ's Avatar
Originally Posted by Phil G4SPZ View Post
…even a BLR121 in there to be re-stuffed…
Ten alkaliine button cells type AG10, GP189, SR54 or LR1130 are a perfect fit at a cost of just £1, inside a length of heatshrink sleeving - just the original battery’s end caps and no spacers are required. The meter now works perfectly on all resistance ranges.
Incidentally, I find on virtually all Avo 8/9 models that the /100 ohms range only zeroes properly after scrupulous cleaning of the battery and the meter’s terminals, together with all connecting parts of the main terminals, test leads and prods. In this case, judicious use of a small rotary wire brush was necessary on the battery terminals. The fuse can also be a source of unwanted resistance.
Phil
Phil G4SPZ is offline   Reply With Quote
Old 6th Feb 2023, 11:08 pm   #3123
stickfly
Received another today.
A Model 7 : 35471 - A - 752
Came in a wooden box with 2 sets of original leads + Multiplier + Shunt.
Couldn't test it as the batteries had swollen up so much I couldn't remove them, I had to remove the battery box first. I couldn't believe how tight the case was, it took an age of careful prising before it would open. Looks like there's a resistor or 2 in the green sleeving. (To replace a bobbin ?)
My next job is to fit holders for an AA battery + PP3 battery and see if anything works.
Regards ..... Gary
(Actually, it won't work with just the batteries sorted as the cut out button won't stay in position, it's permanently popped out.)
ID:	272801   Click image for larger version
ID:	272802   Click image for larger version
Name:	02 - Copy.jpg
ID:	272803   Click image for larger version
stickfly is offline   Reply With Quote
Old 7th Feb 2023, 12:01 am   #3124
Phil G4SPZ
Phil G4SPZ's Avatar
Cut-outs are relatively logical and usually easy to sort out - aim for cleanliness plus freedom of movement, but no lubricants. Don’t do what I once did though, drop the hairspring on a dusty workshop floor took me an hour to find it!
Phil
Old 7th Feb 2023, 12:07 am   #3125
stickfly
Phil, if I could gather up all of the time that I've spent looking for items that I dropped and add it onto my life, I'd have an extra 15 years to go
Regards ..... Gary
Old 7th Feb 2023, 12:54 am   #3126
stickfly
Update Phil,
Just decided to press the cut out button in & out to check how free it is and it has now reset.
So I decided to use a 9v PP3 to see if the DC Volts works : It does but the pointer sticks at 8.2v every time.
Still, it's progress I suppose.
I'll leave it alone until the weekend when I fit the battery mod's.
Regards ..... Gary
Old 7th Feb 2023, 8:37 am   #3127
Phil G4SPZ
Phil G4SPZ's Avatar
It sounds like debris caught in the moving coil’s air gap. Again, a straightforward but delicate job for which the movement will have to be removed.
Phil
Old 9th Feb 2023, 12:36 am   #3128
stickfly
Thanks again Phil.
I've got 5 days off work from Friday and my wife will be at work, so plenty of time to have a good look.
Regards ..... Gary
Old 11th Feb 2023, 11:54 am   #3129
Sinewave
Sinewave's Avatar
Gary, since you've caught Avodiction, there's a model 5 on ebay which you should add to your Avotorium. I have about 5 of them already, so this one's yours
Old 12th Feb 2023, 1:28 pm   #3130
Superscope
If the Model 5 mentioned is the one in the group of Three Avometers for
sale, then be aware that it has the wrong Terminals on it, so they have
been changed at sometime.
Ian
Superscope is offline   Reply With Quote
Old 12th Feb 2023, 6:48 pm   #3131
Sinewave
Sinewave's Avatar
It's still a Model 5 though, not a reason to not get it.
Old 12th Feb 2023, 7:06 pm   #3132
Phil G4SPZ
Phil G4SPZ's Avatar
One reason not to get it is the scaleplate, which will be quite a task to restore.
I am very fond of my own 36-range Model 5, partly because of its very useful 1,000 ohms range which can be read with ease down to 0.1 ohm.
Ian is right about the terminals, which should look like the attached.
Phil
Phil
Old 13th Feb 2023, 10:56 am   #3133
Sinewave
Sinewave's Avatar
Again, I don't think that's a reason not to get it. If its for collecting purposes, it's fine as it is. Ok, it may not be ideal if you want to use it, but the older meters like this I collect and don't use. I did notice the terminals, which look like what are on the HR models, so perhaps it's an indication that it has been used and may well be in good working order other than the scale plate?
I do use some Avometers, but usually much later ones such as the 8 mark 5.
Old 13th Feb 2023, 12:56 pm   #3134
Superscope
Indeed,
My point was only to highlight that fact that the Meter has an incorrect replacement part.
It's important this information is highlighted, so that it doesn't become accepted incorrectly
as being original going forward.
Most collectors I would assume would want their collections to be historically accurate if possible.
Model 5's are not particularly rare, so you don't have to wait to long for one to pop up.
Plenty of very good ones out there, even with good Scaleplates.
Those HR Terminals (actually used on a lot of other Avo equipment) are seen quite
often on repaired Vintage Avo's. The original Terminals had much thinner threads (4BA I think),
than the later ones (2BA) so breakage was probably common.
Ian
Old 13th Feb 2023, 9:18 pm   #3135
Station X
Station X's Avatar
One post moved to a new thread here:-
https://www.vintage-radio.net/forum/...d.php?t=198271
Graham. Forum Moderator
Station X is online now   Reply With Quote
Old 14th Feb 2023, 3:49 pm   #3136
Phil G4SPZ
Phil G4SPZ's Avatar
Quick question: are any of the Avo enthusiasts, collectors, restorers and other contributors to this long-established thread planning to visit the Retro Tech show on 21st May? It struck me that it would be nice to put a few faces to the names!
Phil
Old 14th Feb 2023, 5:20 pm   #3137
Sinewave
Sinewave's Avatar
Possibly. I think we did meet there one year? Years ago this was.
I might do it for a day out, although I really shouldn't be buying anymore equipment. Baby number three arrived three weeks ago, so it's difficult committing to anything that far ahead!
Old 15th Feb 2023, 12:21 pm   #3138
Phil G4SPZ
Phil G4SPZ's Avatar
Babies… congratulations. I know the problem, but in my case with grandchildren!
Nearer the time, perhaps we can agree a meeting time and place.
Phil
Old 20th Feb 2023, 12:23 am   #3139
stickfly
Evening everyone,
Another to add to the list.
Model : Admiralty 48A, Serial number : 12352-943
In box with 2x Shunts + Multiplier + Transformer and leads.
As ex RN I couldn't resist when it was offered to me
Haven't tested the unit yet.
Regards ..... Gary
Name:	01 - Main.jpg
ID:	273593   Click image for larger version
Name:	02 - LH Box.jpg
ID:	273594   Click image for larger version
Name:	03 - RH Box.jpg
ID:	273595   Click image for larger version
Name:	05 - 48A.jpg
ID:	273596   Click image for larger version
Name:	06 - Scale.jpg
Old 20th Feb 2023, 12:35 am   #3140
The Philpott
The Philpott's Avatar
All those bits look to belong together Gary, note the wingnuts on the AC current transformers are rough finished without nickel plating (so they're austerity spec, appropriate to 1943.)
The hand painting on the scale plate was done by the same employee as the Model 47A(S) that i brought in from the shed yesterday- i recognise the handwriting!
The Admiralty meters seem to have had an easier life than the Air Ministry meters, so it's likely to be viable. You might find one or of the high voltage shunts to be open circuit if they're wire-wound rather than component based.
(Heavy, aren't they? You probably have 8kg of test equipment there.)
Dave
The Philpott is offline   Reply With Quote
Reply
