Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > General Vintage Technology > Where To Get Sets and Parts
Where To Get Sets and Parts For discussions about swapmeets, rallies, NVCF and BVWS, car boot sales, antique and charity shops, dealers, newspaper adverts, the local tip and just about any other source of equipment (other than eBay).
Old 13th Dec 2022, 10:04 am   #1
David G4EBT
David G4EBT's Avatar
Default 470K & 1 Meg Switched Pots no longer made.
There was a recent thread entitled "DAC90A with broken DPDT switch help" to which I responded:
https://www.vintage-radio.net/forum/...d.php?t=195903
I'd suggested that Bowood Electronic might be worth a try as for some years they'd been the only firm that I knew of who were able to supply switched log 470K pots as replacements for the 500k Bush DAC90A volume control, and 1 Meg log pots as used by other vintage radios:
https://www.bowood-electronics.co.uk...-log-switched/
Bowood Electronics is a small family firm at Chesterfield run by Will and his wife Janet, who for many years worked for Bardwell's in Sheffield. They will be familiar to rally goers in the South Yorks area, often seen at radio rallies over the years. Their website is well worth a browse.
When I checked the stock at Bowood I noted that both 470K and 1 Meg were out of stock, and had been for a while.
At post #7 of the above thread I suggested that the only other option would be to try Blore Edwards, who will tailor-make switched and unswitched pots with any type of track, and will make a 500K log pot with double pole mains switch, though you'd need to specify all the parameters of what you need as they make them to order. That does have the advantage that you can specify a 6.34mm (1/4") spindle, which will be metal, like the original on the DAC90A, rather than a 6mm plastic shaft that most pots have these days, but I guess it would probably cost more than most DAC90A restorers would be willing to pay, (though I know at least one who has done).
I dropped an email to Will at Bowood:
"Hi Will,
I see that for a while now you've been out of stock of 1 Mg and 470K switched log potentiometers, which are used from time to time by vintage radio restorers. Are you able to give me any indications when these might be back in stock please?"
End quote.
I've just received his response, which does at least provide a 'work-around':
"Yes, if you can give me any indication where I can buy them. These have been discontinued with all my suppliers. With very little demand for high value switched pots it’s unlikely they will ever be produced again. All tv’s, modern radio’s etc are all digital and don’t use potentiometers. You might get lucky on the surplus market or anyone with some old stock".
Good luck with your search.
"The only thing I can offer you would be a 470K linear switched pot and an identical 470K log unswitched pot, the tracks are easily interchangeable, the only problem you will find is that when you have swapped the tracks if turn the control right back just before it clicks off there is still some resistance there, this means you won't be able to turn the volume completely off until you switch off. Kind Regards, Will".
End quote.
The DAC90A is a very commonplace radio, and hardly a day passes on the forum when '90As pop up in one thread or another, with the volume control being one of several known points of failure. That being so, maybe the BVWS could consider getting a batch made by Blore Edwards for sale as a service to to BVWS members only, as they do with the range of capacitors that they stock. I dare say that an order of perhaps 25 would bring the cost down to an acceptable price with a margin towards BVWS operating costs.
Just a thought.
David.
BVWS Member.
G-QRP Club member 1339.
David G4EBT is online now
Old 13th Dec 2022, 10:17 am   #2
vidjoman
Default Re: 470K & 1 Meg Switched Pots no longer made.
There are 500k and 1m LOG pots available from the US. They only have a single pole switch, are 24mm dia and have a long shaft.
Available from - https://www.tubesandmore.com/product...eters_0?page=2
No connection with them but I've had parts from them in the past. Check out the POST & PACKING etc. as it can be an additional cost to make it prohibitive. Haven't ordered anything for a couple of years. Ordered valves and they arrived well packed and promptly.
vidjoman is offline
Old 13th Dec 2022, 10:57 am   #3
Craig Sawyers
Craig Sawyers's Avatar
Blore Edwards have them https://www.blore-ed.com/product-pag...-potentiometer
Ignore the huge minimum order charge, and email them. They sell small orders if you just contact them.
Lots of options. Shaft size and length. Metal or nylon shaft, Bush size. Switch form. Linear, log, reverse log.
And 470k and 1M are standard values. And 2M and 5M too.
Craig
Doomed for a certain term to walk the night
Craig Sawyers is offline
Old 13th Dec 2022, 2:26 pm   #4
David G4EBT
Yes, I mentioned Blore Edwards at post #7 in the thread in my post above Craig, and the specification criteria, suggesting that the person who wanted the pot might wish to give Brett Cryer at Blore Edwards a call, which might save the rigmarole of going through all the ordering criteria.
I wrote:
It looks like the only source would be Blore Edwards Ltd, who will make a 500K log pot with double pole mains switch, though you'd need to specify all the parameters of what you need as thy make them to order. That does have the advantage that you can specify a 6.34mm (1/4") spindle, which will be metal, like the original on the DAC90A, rather than a 6mm wibbly-wobbly plastic shaft that most pots have these days.
What the DAC90A requires is a 'TYPE AR-45 - Single gang with AR MAINS switch'
Specification criteria:
R = Resistance value L = Law (linear, logarithmic or reverse logarithmic)
A = Shaft length from the mounting face (FMF)
B = Bush type, 1/4"(6.35mm), 3/8"(9.5mm) or M10
C = Length of flat if requested
D = Diameter of spindle 3.18mm, 4mm, 6mm or 6.35mm (other diameters are available on request)
E = Depth of flat (5.54mm is standard)
F = Angle of flat (measured from extreme CCW position)
G = Terminal option (solder or PCB)
H = Mains variation (see Mains Switch Contact Arrangement for part numbers)
Unquote.
I rather suspect the the price for a one-off might be more than most impecunious '90A restorers will be willing to pay, but as I mentioned, I do know one forum member who did. Anyone who needs one, will need to do the 'leg-work'. (If the said forum member who bought one from B.E. is reading this, he might wish to let us know how much it cost!)
David.
BVWS Member.
Old 13th Dec 2022, 7:02 pm   #5
Craig Sawyers
I must admit I did not follow the links David
And I did not read far enough down your mail either
Oops!
Craig
Old 13th Dec 2022, 7:28 pm   #6
Pamphonica
Pamphonica's Avatar
From memory, my custom pots from Blore Edwards, including a fiendish twin antilog 1Meg were all under a tenner each including postage, but this was a few years back. Try asking for Brett Cryer. He has been exceptionally helpful in the past. Worth a phone call.
Jeremy, G8MLK, BVWTVM Friend, VMARS, BVWS Secretary.
www.pamphonic.co.uk www.bttt.org.uk
Pamphonica is offline
Old 13th Dec 2022, 9:10 pm   #7
David G4EBT
Oops!
Craig
That's to be expected Craig - I forget to add the warning: 'Reading this might induce drowsiness'!!
David.
BVWS Member.
Old 13th Dec 2022, 10:22 pm   #8
joebog1
May I be cheeky ? Craig.
It might induce education too!!
Joe ducks
joebog1 is offline
Old 14th Dec 2022, 12:18 am   #9
Nuvistor
Nuvistor's Avatar
Careful with that switch, it’s rated at 125VAC.
Frank
Nuvistor is online now
Old 14th Dec 2022, 1:45 pm   #10
JonSnell
JonSnell's Avatar
Current production through RS
https://uk.rs-online.com/web/p/potentiometers/0387880
https://uk.rs-online.com/web/p/potentiometers/7456781
Hanging a 680k between pin 1 and pin 2 (wiper) will roughly mimmick Log.
Valve equipment repairs since 1968 https://jonsnell.co.uk
JonSnell is offline
Old 21st Dec 2022, 11:42 am   #11
FrankB
You might try Mark Oppat here in the States. He has a good stash of snap together control parts and can make up pots to spec.
Contact info; moppat at comcast.net (Use correct symbol and remove spaces).
I have purchased from him over the years and is a good chap.
FrankB is offline
