5th Oct 2022, 3:00 pm | #21 |
Re: Homebrew PSU Problems
I purchased a linear PSU kit from Banggood based around the LM317. Performance was weird and erratic. I dug out an old genuine Nat Semi one from the spares box and all the problems vanished.
Alan G6PUB, BVWS |
5th Oct 2022, 6:02 pm | #22 |
Going back to the question of are they fakes, check the voltage between the adjust pin and output, this should be 1.25V, if it reads about 0.7 then you have been sold a simple transistor and it's working as an emitter follower, this will give a variable output but with no protection.
Just a thought Peter |
5th Oct 2022, 7:26 pm | #23 | |
0.663v on diode check Cheers Jay
Help!! I've been electrocuted by a glass thing that glows Last edited by Radio Scotland; 5th Oct 2022 at 7:30 pm. Reason: extra info |
6th Oct 2022, 9:20 am | #24 |
I actually meant when the regulator is on and working but a diode test of 0.6 certainly looks like you have been sold transistors labeled as regulators, fakes in other words.
Peter |
6th Oct 2022, 9:29 am | #25 |
It would also be of the opposite polarity!
LM317 has its adjustment pin 1.25V -ve to output terminal, whereas an NPN transistor would have the base 0.6 V positive to output terminal (emitter). I've never had any problems with the LM317 except a bit of noise. And I've used lots - they're one of National Semiconductor's triumphs! |
6th Oct 2022, 10:15 am | #26 |
Wouldn't be the slightest bit surprised, Bought them direct from china a few years ago, I'm actually planning on using the LM338 But they seem to have vanished in the post
Help!! I've been electrocuted by a glass thing that glows |
6th Oct 2022, 11:25 am | #27 |
Yup surprisingly enough they seem to be genuine, As tha'ts the voltage I'm getting between adjust and the output
7th Oct 2022, 7:42 am | #28 |
Interestinger and interestinger,
At this stage I would try the following Try an LM317 from a different source. Try the regulator circuit on a bench power supply, not the battery charger, to narrow down the problem. And try as Sideband says in post 13 to mount the capacitors as close to the regulator as possible. Peter |
7th Oct 2022, 11:01 am | #29 | |
Jay
8th Oct 2022, 10:20 pm | #30 |
Are you using your homebrew PSU to charge batteries?
8th Oct 2022, 10:23 pm | #31 |
No. It's just a general power supply for projects etc.
