3rd Mar 2013, 1:12 pm | #1 |
"Universal" valve radio
Hello,
I have a bakelite radio with the brand name "Universal". It works well enough although the reception is very dependant on the angle the radio is at. At the back of the radio there is an aerial wound around the back panel but also a length of loose wire. Can anyone tell me if this is how the aerial is supposed to be? Or can I remove the loose wire? Also, I'd love to know when this was made, I'm guessing the 1940's. And was it a budget radio? (Is is a very simple radio.) Thanks, Oliver. Last edited by Goodfellas; 3rd Mar 2013 at 1:21 pm. |
3rd Mar 2013, 2:20 pm | #2 |
Re: "Universal" valve radio
Oliver,
The dial markings are a clue to the date of your radio. In this case "BBC 3" appears a two points of the medium wave scale - representing the Third Programme, which began in 1946 and became Radio Three in 1967. If the set is not a well-known one, the valve line-up gives some indication of the design philosophy and the valve types will also relate to the time the set was made. Octal, Mazda Octal and similar sized valves were used up until the early 1950s and began to be replaced by types with B7G, B8A and B9A bases from the late 1940s. More exact dating can be set by codes on some components, especially electrolytic capacitors which usually are marked with the date of manufacture. Obviously this depends on their being the originals. In default of a service sheet, a circuit diagram or a sales brochure, photographs of the inside would help with dating. As you are fairly new to the Forum, I hope you won't mind being reminded that any radio intended for AC or DC mains will have a live chassis and needs careful safety precautions when working on it to prevent possibly fatal shocks. You radio is very likely to be "Universal" in this respect too. PMM |
3rd Mar 2013, 2:42 pm | #3 |
Hi PMM, thanks for the info. I'll take a look inside and might post a couple of pictures. I'll take care not to be zapped by it
Any clues as to the aerial setup I mentioned? |
3rd Mar 2013, 7:37 pm | #5 |
There have been a few of these on the forum over the years. Another possibility is that it's a kit set. The cabinet is, I belive, a Pilot Little Maestro-style one, which was marketed by surplus outlets well into the 1960s for amateurs to build their own sets into.
N. |
3rd Mar 2013, 8:10 pm | #6 |
With that case it shouts 'kit' to me. Goodness knows who was the vendor, but the apparent direct tuning drive is somewhat unusual. Does it use Octal or minature valves?
I had one with direct drive to the tuning capacitor, which was a seriously cut down short superhet & had minature 8 pin valves. Terrible performance. Get that back off & let's see what she looks like inside. |
3rd Mar 2013, 10:52 pm | #7 |
Tuning mine is not much fun since it needs very careful tweaking to get a station tuned just right! The radio's been working well all weekend, the output is loud (on some stations), although the sound is a little distorted so maybe it's due some renevation work.
I just looked at "Pilot Little Maestro" on Google images and yes the case is the same, although they appear to use the traditional (and better) method of turning the tuning capacitor! I'll post pics of the valves soon. By the way, I brushed my hand past the end of the aerial wire and got a tingle. I used a mains electrical test screwdriver (the sort with a neon bulb inside) and it glowed dimly when I touched the aerial... is this dodgy? |
3rd Mar 2013, 11:13 pm | #8 |
The tingle and the distortion could both point to electrically-leaky paper capacitors, which you should change before using the set any more. Ask if you need more advice.
Good luck, Nick. |
3rd Mar 2013, 11:15 pm | #9 |
The case can be found used in the "Transportable A.C. Superhet", page 617 of November 1962 Practical Wireless.
Seems like a kit or small production run using surplus parts.
I was so upset that I cried all the way to the chip shop. |
4th Mar 2013, 11:05 am | #10 |
It must be a kit set. There is a point to be made about the case: 'Little Maestro style' was the term used by one contributor to this thread and that's correct - although the case looks at first glance identical, there are subtle differences, the most obvious ones being the shape of the right-hand ribbed pillar. On the 'real' LM case this column of false louves is slightly broader and the front edge of the louvres carries a distinct flat, whereas with the'false' LM, the column appears simply rounded and of very slightly less width. Also noticeable is the flatness of the moulding above the LS grille louvres, where with the LM original there is a distinct slope downwards.
This begs the question: if the original (and costly) moulds were NOT used, why make such a close replica of the case? Was the original mould modified in some way? Did Pilot sell the rights to the design? Was the wooden version (or one of them) of this constructor's case identical to the LM wooden case? I know - I need to get out more... Tony |
4th Mar 2013, 10:30 pm | #11 |
Thanks for all who have confirmed it as a kit, definitely looks like one. I don't mind though, I like its style and it's nice and small compared to my other larger valve radios.
I wonder if the mould they used needed fixing, hence the little differences noticed by Aerodyne. As promised, attached are some pictures of the chassis. |
4th Mar 2013, 10:34 pm | #12 |
Not much mystery regarding the 'guts' of this set. A 3 valve TRF with a metal rectifier.
The earlier ones used military surplus components. The fact you have had a 'tickle' from the aerial wire is alarming. Normally there should be a coupling capacitor between the serial coil & the wire aerial. This should be a low value mica capacitor. Those should not fail, but any other kind that are present ought to be regarded as suspect. Any waxed paper capacitor ought to be replaced without any prior notion of testing them. There is one location where a leaky capacitor can wreak havoc. It is the coupling capacitor to the first grid of the audio output valve. It is referred to as "That Capacitor". So notorious is it that it ought to be the first component to be changed. Alright.. I know I am drifitng off topic. Our new friend needs to know these things. Normally the tuning ought to be driven by a cord between a shaft & a far larger pulley attached to the tuning capacitor to give a reduction. Why the convenient reduction drive was dispensed with puzzles me. Maybe it just wasn't necessary with far fewer stations on the air then? What are the valve types? If that metal rectifier dies it will whiff like a old-fashioned privvy. The HT should be around 200V, as it is derived from the mains & the voltage drop across the rectifier is around 50V. the rest of the Forum can advise on choosing a diode & resistor combo to keep the HT voltage from rising too high. The audio distortion could be down to the leaky grid-coupler capacitor. Find it & change it! Last edited by Neil Purling; 4th Mar 2013 at 10:43 pm. |
5th Mar 2013, 12:44 am | #13 | |
5th Mar 2013, 3:45 pm | #14 |
There's one good thing to get out of all this, TRF's have only a handful of bits to check/replace.
I somehow had a feeling it was a TRF. Oliver, when this set's overhauled & working, don't expect it to perform as good as a super-het, TRF's seem to need a massive aerial before they perform. |
5th Mar 2013, 8:35 pm | #15 | |
Glowing bits commented
Tony |
5th Mar 2013, 9:46 pm | #16 | |
Rich
24th Aug 2013, 4:34 pm | #17 |
Well I finally took the chassis out of the case and can give some more info about this radio. It still looks like a project radio (or built from a kit), there are no brand markings or numbers inside.
There are two Brimar/BVA 6U7G valves. The third valve is hard to identify, one of the numbers is badly printed, it says:- H^A CV1032 KB/T Note: It might say CV1932 instead of CV1032, I've attached a picture. |
24th Aug 2013, 5:05 pm | #18 |
CV1932 looks like a match to your picture- it's a triode equivalent to 6J5G or L63. It doesn't make a lot of sense with a couple of RF pentodes, though.
http://www.r-type.org/exhib/aaa0665.htm 6U7G is a vari mu pentode. http://www.r-type.org/exhib/aaa0665.htm CV1032 is an output valve of sorts, but it's a battery double triode which hardly sounds right either. http://www.r-type.org/static/webcv03.htm Is one of the pentodes doing duty as the output valve? Not impossible- it would be good for maybe a watt of audio.
24th Aug 2013, 5:36 pm | #19 |
I agree actually, after another google images search, it is a CV1932.
I'm alsmost afraid to ask this (and in my defence, I do have an electronics background, but not in valves!), but does this radio lack a valve (or solid state) rectifier? Please see the picture in my previous post. |
24th Aug 2013, 6:21 pm | #20 | |
Tony |
