19th Jun 2017, 12:39 am | #1 |
Quad FM3 problem
Hi all.
Managed to buy a cheap Quad FM3 radio tuner last week. It sounds lovely but when its been on for an hour it suddenly starts going very quiet. If I unplug it and plug it back in again it is fine for a while then does it again, Any ideas please? |
19th Jun 2017, 8:01 am | #2 |
Re: Quad FM3 problem
Hi this is the FM3 user manual with the cct diagram hope it helps
Dave
Any tool can be used as a hammer but a screwdriver makes the best chisel |
19th Jun 2017, 11:19 am | #3 |
I would suggest measuring the +14V and -14V supply lines with the fault present and not present.
19th Jun 2017, 12:07 pm | #4 |
Have you tried twiddling with the "Mute threshold" preset on the back when the fault's present?
20th Jun 2017, 3:37 pm | #5 |
Hello.
I had a range of Quad items from the valve and early transistor period. When I needed information years later, I found by calling Quad they were very willing to provide advice and information sheets. If the company is still trading it may be worth giving them a call. |
20th Jun 2017, 9:49 pm | #6 |
OK thank you
21st Jun 2017, 8:07 am | #7 |
Hi I do have the service manual on PDF but it is too large to post here PM me with an E-mail address and I will send it to you
Dave
