4th Dec 2020, 12:52 pm | #1 |
Double triode ID?
The pinout of this valve appears to be the same as that of ECC83's etc. but it's taller. Total heater resistance is about 8R cold. Only writing visible is "BRIMAR" and "MADE IN".
Anyone know what it might be? Thanks.
4th Dec 2020, 12:53 pm | #2 |
Re: Double triode ID?
Invisible airwaves crackle with life or at least they used to Mike T BVWS member. www.cossor.co.uk Last edited by Cobaltblue; 4th Dec 2020 at 12:54 pm. Reason: Added Link |
4th Dec 2020, 12:57 pm | #3 |
Seems likely, it came from a box of what were largely TV pulls. I'll give it a test.
7th Dec 2020, 9:19 pm | #4 |
Tests perfectly as a 12BH7 so a 12BH7 it is. Now labelled and boxed up in case I ever find a use for it.
Thanks Mike.
8th Dec 2020, 12:05 am | #5 |
The 12BH7 makes a very meaningful bias/erase oscillator valve for tape recorders. In a circuit originally designed for a 12AU7 (ECC82), with which it is pin compatible, it can provisde a useful increase in erase power at the expense of some HT and heater current.
Leon. |
