3rd Dec 2020, 9:39 pm | #621 |
Re: MK14 schematic revisions
Mine just has 4 flying wires that go to the other PROM (top right on board) and plugs into the LHS (high nibble) socket.
3rd Dec 2020, 9:58 pm | #622 |
Yes, I originally did that because that's what the original had. If I do an updated board I'll consider putting in a dual footprint for either type of switch in all locations. The switches are the "D6" style originally made (I think) by CK, but copied by others. They still seem to be available. You used to be able to get caps for the square variant, although I've not seen them latterly - they probably wouldn't be hard to make on a 3D printer though I imagine.
3rd Dec 2020, 10:08 pm | #623 |
4th Dec 2020, 12:14 am | #624 |
4th Dec 2020, 12:33 am | #625 | |
You could probably replace those resistors even on the current issue VI with SM resistors of appropriate length soldered between the pads either on the top side or the underside of the PCB. They could also be replaced with a 4-resistor SIL package if a through-hole was made available for the fifth (common) pin. |
4th Dec 2020, 12:45 am | #626 |
The 'stand up' resistors on Micky are still intact after 40 years, but the ones on Vicky are forever getting knocked over.
A close inspection reveals that 40 years ago I put the body of the resistors hard down to the board. Obviously I paid no heed to overheating the things, now I always leave a bit of wire on show. Ian's effort in re-creating an 'as near as perfect' reproduction of the MK14 is to be commended. I am looking forward to getting my Vicky going, and it would never have been possible without VI. |
4th Dec 2020, 9:53 am | #627 |
As a point of interest those upright resistors are 1/8th watt resistors on my original MK14, those were the resistors SOC supplied, no doubt with the intention of giving them a lower vertical profile. They don't handle any significant current so there would be no problem mounting them with one end the body right down against the PCB.
4th Dec 2020, 12:52 pm | #628 |
I did them like that because thats the way SoC did it, as Sirius said. I can't really see why, it wouldn't have been hard to find somewhere for 4 resistors horizontally. I imagine they may have been a late addition to the circuit and given the original PCBs were probably hand-taped moving stuff around wasn't an option. Much easier these days with CAD tools!
However having a quick look, the size 1/8w resistors are today, they would fit in the space horizontally! |
7th Dec 2020, 6:22 pm | #629 |
New replica on eBay looks pretty authentic, not mine btw! Ive snagged the photos for reference,
7th Dec 2020, 6:39 pm | #630 |
7th Dec 2020, 7:32 pm | #631 | |
https://www.8bity.cz/replika-mk14/mk...ond-prototype/ Click on the English Flag for a translation. |
7th Dec 2020, 9:23 pm | #632 |
How many replicas are there now? Martin L's, The JMP replica, Slothie's issue VI, MK14man's modern tech replica from a few years back and and now also the ones which ortek_service's friend has produced - we don't really have a name for that one yet.
That's not counting known one-off replicas like this one:- https://www.youtube.com/watch?v=vhSAMRwGL-A |
7th Dec 2020, 9:36 pm | #633 | |
They are very close copies of the original SOC issue V, so it's essential that the PCB layout is widely preserved. I think the only difference is that the original PCB was laid out for 3-point switch domes and Martin laid his keypad traces out for 4-point domes, which was all he could get at the time. |
7th Dec 2020, 9:55 pm | #634 | ||
Next time I have the scanner out I will do as asked. |
7th Dec 2020, 10:24 pm | #635 |
..and don't forget to lay a rule alongside the edge of the PCB when you scan it (both sides) - it's the easiest way for people to check that the image on their screen really is actual size when they are trying to make measurements from it.
7th Dec 2020, 10:30 pm | #636 |
Thanks to Tim for his post https://www.vintage-radio.net/forum/...&postcount=134 that has a link to the corrected MK14 manual with the missing page 88 restored. This is the last part of the moon landing program, but more importantly the first part of the "Duck Shoot" program that I wasted an unfeasible amount of time on as a teenager with my teachers MK14!
I'd second the vote for the use of a ruler of some kind on any scans of the PCB! |
7th Dec 2020, 10:36 pm | #637 |
I always used to change the character definition for the 'Duck' because I didn't think the default character looked enough like a duck. I must have been a lonely child...
8th Dec 2020, 4:06 am | #638 | |||
8th Dec 2020, 10:02 am | #639 |
I'm seeking to preserve it, not to reproduce it, and only because it is the closest 'living' thing that there is to the actual layout of the original issue V - except for the odd unbuilt ACTUAL issue V PCB which may still be out there in the wild somewhere.
It would, admittedly, assist with things like reproducing the correct key spacing on a future revision of the issue VI but that would not be a wholesale copy. |
8th Dec 2020, 11:59 am | #640 | |
I already have photos of both sides of an original PCB, but they are from an eBay listing, and have no size reference, are of an issue IV (I'd prefer an issue V), are not particularly well focused, and are distorted because they are not photographed from directly overhead. I'd like to make a PCB design of the original (including the original contact arrangements) even if its just a retouched photo to the exact scale so that exact measurements could be made, and to actually document the original. Its not about making copies of Martin's work, it just acknowledges that he seems to have come closest to producing a clone of the original PCB. As far as making a clone of the MK14 I'm happy with my "interpretation" that physically resembles the original but is routed differently, but I'd still like to be able to have a precise diagram of the original PCB layout for posterity if its at all possible, and a scan of Martins board would be a valuable reference towards making that. If Tim just scans the PCB and hangs onto it himself before assembling it that would be something, in case permission was to arrive in the future. I have made some attempt to "enhance" the images I have of an original board, and to remove the distortions, but with the poor quality of the image and having to estimate dimensions using the IC pins as a "ruler" I have had limited success and I need to spend some time writing a program to remove the dimensional distortion from the image - its kind of towards the bottom of my "to-do" list. Of course, if someone has an issue V and doesn't mind disassembling it and scanning the PCBs... |
