Old 29th Nov 2020, 12:16 pm   #1
MurphyNut
MurphyNut's Avatar
Default Loud pop when turntable switches off
I've recently restored and Bush SRP31D and very pleased with it's performance but its just developed an annoying fault.
After it's finished playing a record and the arm returns to the cradle the turntable automatically switches off and makes quite a loud popping noise from the speaker.
I'm wondering what's causing this and how to sort it out!
Thanks
Clive
MurphyNut is offline
Old 29th Nov 2020, 12:19 pm   #2
Michael Maurice
Michael Maurice's Avatar
Default Re: Loud pop when turntable switches off
The cause is likely to be due to the switch contacts arcing. I suggest you add a capacitor of about 10nF across the contacts, or perhaps a suppressor which is usually a C & R in series.
Forum Moderator
Michael Maurice is offline
Old 29th Nov 2020, 12:21 pm   #3
Edward Huggins
It needs a "switch click suppressor" - in other words a large value (c 0.1uF 500V) cap wired across the motor switch. They used to be standard on some higher end Garrard turntables.
Edward.
Edward Huggins is offline
Old 29th Nov 2020, 7:12 pm   #4
MurphyNut
MurphyNut's Avatar
Thanks very much for the advice, will add the said capacitor tomorrow and report back.
Clive
Old 29th Nov 2020, 10:09 pm   #5
Michael Maurice
I think 0.1uF is too big unless it includes a series resistor, thats why I suggested 10nF (0.01uF), make sure its an X rated type, ie 275V AC.
Forum Moderator
Old 30th Nov 2020, 1:20 am   #6
fetteler
fetteler's Avatar
Absolutely agree.
Steve.
fetteler is offline
Old 30th Nov 2020, 9:20 am   #7
John10b
Just as an observation I note that 0.1ufd are used in some Bush Radios, without a series resistor.
John10b is offline
Old 30th Nov 2020, 9:53 am   #8
PaulR
PaulR's Avatar
I have found purpose made snubbers very helpful for this.
Paul
PaulR is offline
Old 30th Nov 2020, 10:02 am   #9
John10b
Reference my post #7, I was thinking of mains suppression so please ignore my observations, must put brain into gear
John10b is offline
Old 30th Nov 2020, 1:05 pm   #10
MurphyNut
MurphyNut's Avatar
I've just got back to this before I fitted the capacitor.
I've checked my "stock" and found I have just 1 uF and .22 uF X rated (275V) capacitors, I don't know how critical this is, will either of those do or should I order a 0.01 uF as recommended?
Clive
Old 30th Nov 2020, 3:06 pm   #11
Sideband
Sideband's Avatar
Much too high. Best order a .01 (10nF) 275V.
Sideband is offline
Old 30th Nov 2020, 6:36 pm   #12
A 0.22uF with 100 ohms in series will be fine.
Old 30th Nov 2020, 9:08 pm   #13
Sideband
Sideband's Avatar
Best thing to do is just try it. Sometimes theory and practice don't always go hand in hand!!
Sideband is offline
Old 4th Dec 2020, 1:02 pm   #14
MurphyNut
MurphyNut's Avatar
The first couple of posts suggested the cap is wired across the motor switch contacts. I assume this is in parallel.
Anyway, I've received the correct rated capacitor and wired it in as this and it's sorted out the problem, hardly any noise to worry about now, many thanks for the help
Clive
Old 4th Dec 2020, 1:29 pm   #15
BRASSBITS
so what type and value cap did you use.
BRASSBITS is offline
Old 4th Dec 2020, 3:06 pm   #16
MurphyNut
MurphyNut's Avatar
0.01uF, X rated type, 300V
Clive
Old 4th Dec 2020, 5:06 pm   #17
Richardgr
Question to the boffins - if you have a double pole switch where live cannot be determined (European plugs) then two capacitors should be fitted? Or is it just one for the whole circuit?
Richardgr is offline
Old 4th Dec 2020, 6:30 pm   #18
One across each switch, the "liveness" doesn't matter, one will switch first. Which one one never knows. (The first time I have done "one one")
